Activity Forums VEGAS Pro White background
  • White background
    Posted by Hiran De silva on October 8, 2011 at 9:25 am
    Hope this is the right place to ask a general question.
    I want a White Background behind me (as I speak to camera, like Apple iPad commercial). I have a white wall but it is not lit enough. I have a photoflood lamp pointing to it, positioned behind me so it does not show, but still is not lit enough (especially on the edges).
    It there a better way? I have a green cloth but that might be overkill for just a white background?
    Is there some effect in Vegas Pro perhaps? Thanks for any ideas.
    Hiran De silva replied 14 years, 11 months ago 6 Members · 10 Replies
  • 10 Replies
  • Graham Bernard
    October 8, 2011 at 9:37 am
    If you can do some footage without you in frame, capture this back to the timeline above or below your main, track motion it to obscure the shadows and then mask out what you don’t want.
    You could try inverting the new footage si that which is dark will be lit and so on.
    If you wish to give me a STILL of with and then without you I’d love to have a go.
    Apart from evenly lighting it from the start, I’ve got other ideas.
    Grazie
  • Hiran De silva
    October 8, 2011 at 10:21 am
    Graham,
    A ‘dummy’ is here. Here the background is lit with a table lamp. 500W photoflood does a better job (but not enough).
    https://www.anewkindofexcelexperience.com/
    The background can be a plain white image.
    Thanks for help.
    Hiran
  • Bob Peterson
    October 8, 2011 at 10:51 am
    Try adding more lights. It’s always better to let the camera capture the desired result.
  • Hiran De silva
    October 8, 2011 at 10:56 am
    Bob, I was thinking the same. Moving to another room where there is more light also.
  • Frank Stevn
    October 8, 2011 at 12:08 pm
    The light is not perfect, but is acceptable. If you make it perfect white, your message won’t be impacted very much.
    If I where you I would focus on the sound. Use a lavaliere mic to avoid the room echo. Your message will be perceived to be more professional.
  • Mike Kujbida
    October 8, 2011 at 12:14 pm
    D. Eric Franks (he used to be a moderator on here) did a great tutorial on this technique.
    Lighting Infinite White
  • Hiran De silva
    October 8, 2011 at 12:40 pm
    Frank, I used a Rode NTG-2 Dual Powered Shotgun Condenser Microphone with far too much reverb (in this test). I have a lapel mic I shall experiment with. Good point.
  • Hiran De silva
    October 8, 2011 at 12:51 pm
    Thanks. That’s a brilliant video tutorial!
    Here’s a test I did last year (I just found).
    https://www.askhiran.com/excelexperience/default_ooh.asp
    This kind of background will do. (excuse the silly stuff! and amateur graphics. Now done with PowerPoint https://www.askhiran.com/excelomg/introvideo.asp)
    Hiran
  • Stephen Mann
    October 8, 2011 at 5:42 pm
    [Hiran de SIlva] “Frank, I used a Rode NTG-2 Dual Powered Shotgun Condenser Microphone with far too much reverb (in this test). I have a lapel mic I shall experiment with. Good point.”
    If the microphone -ANY microphone- is on the camera, you *will* get room echo.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Hiran De silva
    October 8, 2011 at 6:16 pm
    Stephen, mic-on-camera (for me) is much worse than that! My cam is a Sony Handycam and is very very very noisy!
    The Rode mic is close to me, pointing at me, and recording the audio to a digital recorder (at 48khz so it syncs in Vegas Pro properly, thanks guys). But will try the lapel mic (as suggested) which would be even better.
