Activity › Forums › Avid Media Composer › whip pans
  • Posted by Toby on July 3, 2005 at 5:41 am
    Hiya, hoping siomeone can help, I’m wanting to create a whip pan effect. I kind of presume that I will have to keyframe a motion blur at the tail end of the first clip and at the top end of the second and then put a fast push transition inbetween, I’m hoping for the best possible results as allways, so can anyone please help. I dont normally use these types of effects, because I edit news, but I have a hankering for trying to make a couple of the stories a bit more extravagant I’m using express pro at home but newscutters and adrenalins at work, although I presume that the solution will be the same across the board. Any help is much appreciated!
    Toby replied 21 years, 2 months ago 2 Members · 4 Replies
  • Paul Ingvarsson
    July 4, 2005 at 10:29 am
    On V1 use a push effect between 2 clips, on v2 add a horizontal blur on a segment of filler keyframing 0 > 100 > 0 (%). I usually make the blur exceed the length of the transion by a frame or two either end.
    You don’t mention what system you have or plugins so I can’t say exactly what effects to use…
    Paul
  • Toby
    July 4, 2005 at 11:05 am
    Thanks Paul, I tried that today, and it works just fine, I use express pro at home, and adrenalin and newscutters at work. The only problem that i seem to get is that in the pushes there seems to be a thin black border, this is not part of the effect, as we were able to add a proper border too, it seems that when ingesting from SX tape we always get these lines when pushing horizontally, but not when pushing vertically.
  • Paul Ingvarsson
    July 4, 2005 at 11:50 am
    Toby,
    That is your analogue blanking you are seeing. It’s quite normal.
    To get rid of it place a DVE on each clip either side of the transition and set the scale so that the line blanking is removed (look in you record viewer – not the external monitor.
    Paul
  • Toby
    July 4, 2005 at 8:38 pm
    Thanks very much for your help Paul, I’ll give that a go today, I knew it had to be something to do with ingesting analogue, because I dont get the problem when using P2 camera cards. Thanks again.
