Activity Forums DVD Authoring Which way is better?
  • Which way is better?
    Posted by Shahram Ashkani on July 15, 2007 at 9:06 pm
    Hello
    I have a problem, can anybody help me?
    I have a DVD-Video and I want to edit it in editing application (Edius) and then again I want to create new DVD-Video from it with new menu and subtitle.
    Since my capture card has been damaged and right now I just have IEEE 1394, I think I can do it in two ways;
    1- capture DVD-Video by IEEE 1394 as an AVI file and edit it in Edius and then export final video as a MPEG2 file and in the next stage take them to DVD authoring application and create DVD-Video with new menu and subtitle.
    2- Importing Vob file directly to Edius(it support vob files) and edit it, then export final video as a MPEG2 file and then send them to DVD authoring application for creating new DVD-Video.
    In your opinion which way is better? What would you do if you were me?
    Quality and resolution are most important factor for me, I don
    Shahram Ashkani replied 19 years, 2 months ago 3 Members · 7 Replies
  • 7 Replies
  • Noah Kadner
    July 15, 2007 at 9:13 pm
    Is it a copy-protected, commercial DVD or one you authored?
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Shahram Ashkani
    July 16, 2007 at 3:58 am
    No it is not copy protected, I can capture it by IEEE1394 and can rip it to hard too but I am not sure which way is the best?
  • Noah Kadner
    July 16, 2007 at 5:09 am
    I’d try to find the original media- DVD is a horrible source for good quality. I’d go with whatever looked best on a disc by disc basis otherwise. DVD to DV is going to be quickest.
    Noah
  • George Wing
    July 16, 2007 at 2:31 pm
    What type of “Editing” do you plan to do? Straight cuts, or something more such as compositing and adding titles, etc…?
    Regards,
    George
  • Shahram Ashkani
    July 17, 2007 at 9:59 am
    Noah, there is no original media, this DVD-video is all we have.
    Yes George, I want to remove and add some part of video and change entire audio of video, I might use some filter like color correction (not so much) and after that I want to export it to Adobe Encore DVD for authoring.
    Regards
    shahram
  • George Wing
    July 17, 2007 at 10:49 am
    What is the resolution of your current DVD? If it’s anything but 720×480/576 (NTSC/PAL), then I believe Encore will re-encode (someone correct me if I am wrong). In other words, some DVD Recorders use 704×480, but Encore will re-encode to be 720×480 (I do not know if Encore CS3 does this).
    If you find you do have a resolution that forces Encore to always re-encode, you might be better off converting to a more edit-friendly format (dv .avi as you have suggested). Then encoding properly for Encore (try to minimze the number of re-encodes).
    Regards,
    George
  • Shahram Ashkani
    July 17, 2007 at 10:48 pm
    Resolution is 720X480 NTSC, Encore2 will re-encode it but I don
