Activity › Forums › Square Box CatDV › Which version of Java
Posted by Robb Harriss on September 16, 2014 at 5:19 pmI just tried to give v11 a spin. I got the error: “Unable to load Java Runtime Environment.”
This happened when trying on both OS X 10.7.5 and 10.9.3. CatDV 10.1.2 runs just fine. Does the new version require a different Java? I’m running Java 1.6.0_65. I’m running workgroup and I don’t want to screw up anything (especially with my Mac Pros stuck running 10.7.5) with a bad Java upgrade (memories of past issues arising).Non-linear: all the time and nothing but.
Robb Harriss replied 11 years, 12 months ago 3 Members · 6 Replies -
Dougal Matthews
September 17, 2014 at 8:43 amhi Rob
Catdv 11 is a 64bit application and requires java 64 bit to run
by default the stock Java 1.6.0_65. on macs is 32 bit only, so you need to install java 7 which is a 64bit java install you will then be able to install and run catdv 11
you can read more on the java.com website here https://www.java.com/en/download/faq/java_mac.xml and also download the latest version
thank you Dougal
Improvise Adapt and Overcome
John Vaudin
September 17, 2014 at 9:09 amAlternatively you can download the “fat” version of CatDV from our we site, which includes the correct Java runtime, so you don’t need install lit separately.
Robb Harriss
September 17, 2014 at 2:00 pmOk. But tell me this. Will the later version of Java run on 10.7.5 that’s on my main MacPro2,1 that’s from 2007? Yes, I know it’s old. But I have two of them and they’re still the primary work machines until we get new ones (which are months overdue). I don’t want to wipe out the older Java just to find out that the new one won’t work and I have to dig around to find the old one again and spend all the time fixing. Been there before.
ThanksNon-linear: all the time and nothing but.
Dougal Matthews
September 17, 2014 at 2:08 pmhi Rob
from the java help page i linked you to earlier
I do not have Mac version 10.7.3 (Lion) or higher. How do I get Java for other Mac versions?
For Java versions 6 and below, Apple supplies their own version of Java. Use the Software Update feature (available on the Apple menu) to check that you have the most up-to-date version of Apple’s Java for your Mac.
Users of Lion Mac OS X 10.7.1 and 10.7.2 should upgrade to 10.7.3 or later versions, so you can get the latest Java 7 version from Oracle.so for 10.7.5 you will be fine as the minimum requirement is 10.7.3
thank you Dougal
Robb Harriss
September 17, 2014 at 2:12 pmAh, very helpful and reassuring. I can move ahead on this. Life will be a lot easier when I finally get newer machines at the studio. I have to run home when I want to use Media Composer 7, Pro Tools 11 or Resolve (now 11.1). Hoping that Pegasus is answer a lot of problems.
