Activity › Forums › Apple Final Cut Pro › Which text generator in FCP X builds titles from the bottom upwards and centers left-aligned titles according to the longest line?
  • Which text generator in FCP X builds titles from the bottom upwards and centers left-aligned titles according to the longest line?
    Posted by Leonore Verster on March 4, 2018 at 4:50 pm
    We have searched through all possibilities in FCP X to find a title generator that allows for the following:
    1. Titles that are bottom-aligned AND that build from the bottom up. First line sits at the bottom of the screen, and only moves one line higher if a second line is added.
    2. Titles that left-align double-speak (those titles with dashes that indicate that we are dealing with 2 speakers), and while aligning both dashes on the left-hand side, the whole title is centered according to the longest line:
    3. Titles are placed directly on the picture without a shadow or gradient.
    In EZ Titles, this happens automatically. We can manually lef-align subtitles where 2 people are talking, but in FCP this takes the titles way off centre and most off the screen.
    Andreas Kiel replied 8 years, 6 months ago 6 Members · 13 Replies
  • 13 Replies
  • Bill Davis
    March 5, 2018 at 7:09 pm
    You might be a bit stuck thinking in a specific process you used to employ.
    Do you really need a specific “tool” for this? X can make this pretty easy using just it’s native tools.
    Just create a regular text title which is left aligned and formatted as you like for font, size, etc. Place it on your storyline and adjust it into the position you want your single titles to originate. Stretch this out the ENTIRE Length of your project.
    Delete any temp text you might have used to create this. (Your goal is clean slugs without any content in case you want a space without any title later.)
    Watch your film and BLADE this empty title holder into TITLE SLUGS that match where you want the captions to change. These will be your “baseline slugs.”
    Go to the first slug and type in a temp title.
    Duplicate it (Option Drag) it into position above the first title. Use this to set the position of the second tier of titles. Copy Attributes for it’s position. Delete the text to get a blank slug again.
    (If you want THREE tier stacks, or more, just repeat as needed.)
    Now Select ALL the empty baseline slugs – and option drag a second copy of them all above the first as connected clips.
    Select all the second title string clips and Paste Attributes (position) to lock blank text slugs above the originals.
    Now just double click each and type in your copy as needed.
    This whole setup process should just take just a few minutes.
    Now just type in your titles as needed.
    Pro tip: If you don’t want to mouse around to type in your copy lines – use your timeline index. You can just arrow down and type everything in the TI as you need.
    There are other ways to accomplish this stuff via outside programs like word processors and/or database approaches like Filemaker Pro – but unless you need tons of special tools – this is pretty easy and requires nothing else past what’s already built into X.
    FWIW.
    Creator of XinTwo – https://www.xintwo.com
    The shortest path to FCP X mastery.
  • Oliver Peters
    March 5, 2018 at 8:52 pm
    Go back and re-read the post. They are asking about subtitles (open captions), which is a very specific requirement.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Oliver Peters
    March 6, 2018 at 4:06 pm
    Maybe this?
    https://www.subvertapp.com
    – Oliver
  • Leonore Verster
    March 6, 2018 at 6:41 pm
    Thank you – this is looking promising. We will try this over the next couple of days.
    Much appreciated!
    Leonore
  • Bouke Vahl
    March 6, 2018 at 7:05 pm
    Ah,
    now I understand what you mean.
    This is really ugly IMHO, and I’ve never seen it…
    I would not bother and convince the rest that all centered is the ‘normal’ way of doing stuff.
    Bouke
    http://www.videotoolshed.com
  • Andreas Kiel
    March 7, 2018 at 3:03 pm
    This formatting had been used quite often and still is in use. But with the usage of proportional fonts it’s more ore less not supported anymore.
    Spherico
    https://www.spherico.com/filmtools
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
  • Leonore Verster
    March 7, 2018 at 5:13 pm
    Thanks again!
  • Brett Sherman
    March 8, 2018 at 1:39 am
    I think you could accomplish this with a Motion template. The sliding up part at least. Centering you’d have to do manually as there is no way to get one title in FCP X to communicate with another title. I made a quick and dirty one that will slide up everything under the title. You’d have to stack your titles, then to keep it from sliding up the video, you’d have to compound all the subtitles together.
    You can download it here:
    https://www.dropbox.com/s/45vgwlw1f7pvevg/Bretts%20Subtitle%20Push%20Up.zip?dl=1
    Here is how you stack your titles:
    Then you have to compound it to keep it from affecting video below titles:
    Hope this helps.
    Brett Sherman
    One Man Band (If it\’s video related I\’ll do it!)
    I work for an institution that probably does not want to be associated with my babblings here.
  • Andreas Kiel
    March 8, 2018 at 10:36 am
    [Brett Sherman]I think you could accomplish this with a Motion template …
    Probably not with “plain vanilla” Motion tools. You’ll need some fxPlug programming knowledge.
    Leonora wants to do subtitling. For subs screen is divided into 9 regions, each 3 for Top, Center, Bottom. Those might overlap depending on allowed lines and font size.
    Horizontally each of those 3 regions will overlap calculated by font size and allowed count of letters letters.
    All of the 9 regions do have an horizontal alignment and “text build” (top, bottom, center) setting.
    If those region would be numbered 1-9 (from left to right and up down) Leonora asks for a region 8, left-aligned and “displayed-after” setting.
    In Motion you can only get parts of those needed values automatically.
    Manual fine tune is not really an option with subtitling – we are talking about hundred, thousand and more “clips”.
    – Andreas
    P.S.
    In FCP 1-7 you can do that with fxScript 🙂
    Spherico
  • Brett Sherman
    March 8, 2018 at 1:14 pm
    Agreed. Depends on the usage. my template would work for a 3 minute video, but not for a 30 minute show. There are tons of manual open-captioned videos posted on Facebook everyday. In fact, whenever you see open captions on FB I pretty much guarantee they were done manually.
    I know how to do .srt import (with your utility), but honestly it’s less time consuming to manually open-caption for a short video, so that’s what I typically do.
    Brett Sherman
    One Man Band (If it’s video related I’ll do it!)
