Activity › Forums › Apple Final Cut Pro Legacy › Which software should I use to get results like this?
  • Which software should I use to get results like this?
    Posted by Geoff Bell on December 20, 2010 at 11:58 pm
    Hey guys,
    I’m currently editing some 7D footage on FCP 7 as Apple Prores LT.
    I want to attempt to create a titles package.
    I am interested to know how the following results would be achieved…
    (Please view from 0:25 to 0:40)
    https://www.youtube.com/watch?v=iS8KXHBCimo
    What software package would you recommend to do this?
    I also like the flame/distorted tv transitions they use.
    Are they a recognized plugin?
    Many thanks
    Shawn Miller replied 15 years, 9 months ago 7 Members · 6 Replies
  • Dennis Radeke
    December 21, 2010 at 12:15 am
    Probably Boris Continuum with a host application (After Effects, FCP, Motion, etc.) is the easiest fit.
  • First Last
    December 21, 2010 at 12:49 am
    Autodesk
    Go fly fishing.
  • Rahul Duggal
    December 21, 2010 at 3:18 am
    The Distorted TV Footage is available as a video filter in FCP6 (so it should be available in FCP7 as well)
    Give it a shot , it might suit your needs.
  • Tony Brittan
    December 21, 2010 at 3:23 am
    I only watched a little bit but you’d be best suited using After Effects or Motion. Also, some compositing packages like those found at Digital Juice or Videocopilot.net will go a long way to give it some depth.
    Good Luck!
    Tony Brittan
    Owner – Island Shore Productions
  • Adam Taylor
    December 21, 2010 at 10:53 am
    i think videocopilot have an AE plug-in called Twitch – that does this kind of effect. I also think Andrew Kramer did a tutorial showing how to get a very similar look.
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Shawn Miller
    December 21, 2010 at 7:29 pm
    Autodesk…. Flint, Flame, Maya, Mudbox, Combustion…. help us out here 🙂
    Personally, I would use After Efffects and Cinema 4D for this.
    Shawn
