Activity Forums Compression Techniques which settings in compressor for MOV-Container, PAL(SD)-resolution, DV-Code
  • which settings in compressor for MOV-Container, PAL(SD)-resolution, DV-Code
    Posted by Per Olsson on March 30, 2011 at 8:29 am
    Hi!
    Im going to send a screening copy to a film festival. They want the following format:
    MOV-Container, PAL(SD)-resolution, DV-Codec, output field: bottom
    first, 48 KHZ, 16 Bit
    Right now I got this:
    Frame size:
    1440x1080
    Vid Rate
    25 fps
    Compressor
    HDV1080i50
    Pixel Aspect:
    HD (1440x1080)
    Audio format
    16-bit integer
    Audio Rate
    48 Khz
    when I resize the file to get it into SD PAL shall I then use the resize tab (on quicktime settings) and choose:
    framesize: 720x576
    Pixel Aspect: PAL CCIR601 (16:9)
    correct?
    which settings shall I use in compressor to get the best quality?
    thanks
    perik
    Michael Nolting replied 14 years, 11 months ago 3 Members · 6 Replies
  • Jeff Greenberg
    March 30, 2011 at 10:57 am
    [Per Olsson] “which settings shall I use in compressor to get the best quality?
    Use the PAL DV preset.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Michael Nolting
    October 11, 2011 at 4:50 am
    Jeff, I was reading your post looking for an answer similar to this. I have compressor 3.0.5 I need to compress a project on my FCP timeline that is SD to PAL to be used in New Zealand.
    I dont see a “DV Preset” in Compressor. I see the following 5 presets:
    1. mpeg -4 basic pal for modem streaming
    2. mpeg – 4 improved pal for cd
    3. mpeg -4 improved pal for east cable streaming
    4. mpeg – 4 improved pal large progressive
    5. mpeg – 4 improved pal small progressive
    I compressed a 1 hour video using preset 1. It produced a 500 meg file, this cant be right! My mpeg -2 files usually create a 3 gig file.
    Am I right to set the size to 576 lines in 4:3 format??
    The inspector has a lot of other settings that I am not sure of.
    Your help greatly appreciated.
  • Jeff Greenberg
    October 11, 2011 at 10:53 am
    In the settings box of compressor, you should see the following folders:
    Apple Devices, DVD, Formats, Other workflows.
    If you don’t see these 4, something is wrong.
    In Other Workflows/Advanced format conversions/Standard Definition
    There should be a DV-PAL preset.
    Alternately, you should be able to type DV into the search box of the settings window.
    Let me know what happens
    Best,
    Jeff G
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
  • Michael Nolting
    October 12, 2011 at 4:29 am
    Jeff,
    Thanks for the info. I was not sure that compressor would convert video formats as well as compress.
    However……………….
    The process is painfully slow, how slow??
    The rate that it went, I was able to calculate that a 2 hour video would keep my MAC busy for over 7 days straight. IMAC with Core I5, 2.5 gig CPU.
    This is not acceptable.
    There has to be a better way.
    Mike
  • Jeff Greenberg
    October 12, 2011 at 11:00 am
    Mike,
    Something else is going on. It certainly shouldn’t take that long. At the longest, it should take 2-3x the timeline.
    See if Compressor Repair fixes it.
    One thought, how are you getting it from FCP to Compressor?
    Best,
    Jeff G
  • Michael Nolting
    October 12, 2011 at 9:30 pm
    Jeff,
    I am going via “File” — “Export” —Export to Compressor, in other words , from the time line, as I do for my NTSC projects which run about 1.25x.
    I have received info from another source that it would be very slow.
    Mike
