Activity › Forums › VEGAS Pro › Which rendering will produce a pretty good size video, in terms of megabytes?
  • Which rendering will produce a pretty good size video, in terms of megabytes?
    Posted by Jeremy Buhain on March 20, 2013 at 5:37 pm
    I use Sony Vegas 12, and my main goal is to render a video that doesn’t take up too much space. I tried rendering .avi, but it ended up being 25 GB. I don’t know if that’s really just how large it is, but I can’t even play it on my computer. It lags tremendously.
    I’m not really sure how to fix this. I was looking up random things, and I saw someone suggest using mp4 using Sony AVC/MVC AVCHD 1080-60i template, but I can’t find a way to change the output to mp4. The System tab under the “Customize template” window is just gray.
    Thayalan Paramasawam replied 13 years, 6 months ago 3 Members · 2 Replies
  • John Rofrano
    March 21, 2013 at 12:19 am
    [Jeremy Buhain] “I use Sony Vegas 12, and my main goal is to render a video that doesn’t take up too much space. I tried rendering .avi, but it ended up being 25 GB. I don’t know if that’s really just how large it is, but I can’t even play it on my computer. It lags tremendously.”
    AVI is just a container. The size of the video is determined by the CODEC that is used to encode the video. Without knowing what AVI template you used, it’s hard to say why it was so large but assuming you used something like Sony YUV the file should be huge because that is a lossless format to be used as an intermediary format not as a final render format.
    [Jeremy Buhain] ” I was looking up random things, and I saw someone suggest using mp4 using Sony AVC/MVC AVCHD 1080-60i template, but I can’t find a way to change the output to mp4. The System tab under the “Customize template” window is just gray.”
    That’s because AVCHD doesn’t use an MP4 extensions. Again MP4 is just a container for MPEG4 video.
    Try using MainConcept AVC with one of the “Internet HD …” templates. That will produce MP4 files that are small in size but high in quality.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Thayalan Paramasawam
    March 21, 2013 at 7:17 am
    thanks mr.john….its help me to
