Activity Forums VEGAS Pro Which rendering format for DVD player?
  • Which rendering format for DVD player?
    Posted by David Payne on December 15, 2007 at 12:28 am
    I’m trying all different rendering formats to try and save a project I did in school to be able to play on a DVD Player , i’ve trieed all different ones but nothing is working. pls help
    Edward Troxel replied 18 years, 9 months ago 3 Members · 4 Replies
  • Terry Esslinger
    December 15, 2007 at 5:07 am
    You need to save it as MPg2 (the language of DVDs). Use the main Concept Preset whic will render just the video. Then render the audio as AC3. They should both go into the same folder. If you are using Arch. then add the video file and the audio file will follow automatically.
  • Edward Troxel
    December 15, 2007 at 2:56 pm
    Take a look at Vol 1 #7 and Vol 4 #1 of my newsletters at http://www.jetdv.com
    Edward Troxel
    JETDV Scripts
  • David Payne
    December 15, 2007 at 9:32 pm
    Tried all that and it still won’t play on my DVD player , I’m using DVD-R discs if that means anything.
  • Edward Troxel
    December 16, 2007 at 3:56 am
    Is the DVD player compatible with burned discs? Does it require -r only? Does it require +r only?
    Look it up in the compatibility charts.
    Edward Troxel
    JETDV Scripts
