Activity Forums Apple Final Cut Pro Legacy Which prefs file determines the default multiclip mode?
  • Which prefs file determines the default multiclip mode?
    Posted by John Adams on May 23, 2010 at 2:40 am
    A challenge to all tinkerers out there —
    I want to change the default multiclip mode (ie. the default selection in the dropdown menu in the dialog box that appears when you ‘make multiclip’). I want to change it from In Point to Timecode.
    I don’t know of any way of changing this via the GUI — so I figure it must be controlled by a line of script hidden away somewhere in one of the prefs or config files…
    I’ve had a quick look at some of the pref files using pList Editor, hoping to find something obvious to tweak — but I’m no codehead, so I’m probably not looking in the right place.
    Anyone have any hints where it might be listed? Or, is there a different way to achieve this?
    cheers
    FCP 6.0.6 // OSX 10.5.8 // 2.66 Quad Mac Pro
    http://www.tinypalace.net
    John Adams replied 16 years, 4 months ago 2 Members · 2 Replies
  • Tom Wolsky
    May 23, 2010 at 3:55 am
    It’s not a preference. It must be in the application code. Tinkering with that is a violation of the EULA.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • John Adams
    May 23, 2010 at 4:20 am
    cheers for the reply, Tom.
    That’s too bad — I thought it might’ve been similar to After Effects which allows some of its UI setup to be tweaked via its pref files.
    thanks
