Activity › Forums › DaVinci Resolve › Which of my two installed GPU’s will Resolve Lite use (Windows)
  • Which of my two installed GPU’s will Resolve Lite use (Windows)
    Posted by Tim Tyler on January 1, 2012 at 6:29 pm
    Installed on my Windows box, I’ve got a GTX460 feeding my displays and a GTX570 that I want Resolve to use for a GPU.
    How do I know Resolve is using the GTX570?
    Tim Tyler
    Margus Voll replied 14 years, 8 months ago 3 Members · 7 Replies
  • 7 Replies
  • Margus Voll
    January 2, 2012 at 8:52 am
    Playback speed changes if you use only gui gpu and or secondary.
    With dedicated secondary card you get noticable speed pump.
    Also in the app start the number of gpus is also shown.
    Margus
    https://iconstudios.eu
  • Tim Tyler
    January 2, 2012 at 4:47 pm
    Margus,
    Where in Resolve does it show the number of GPU’s utilized?
    Tim Tyler
  • Joseph Owens
    January 2, 2012 at 6:35 pm
    [Margus Voll] “With dedicated secondary card you get noticable speed pump.
    Also in the app start the number of gpus is also shown.”
    Since this question is specifically titled “Resolve Lite”, this response is moot. Lite only uses one GPU, and is specifically written to run with systems that only have one GPU. I’m going to assume that your second GPU is totally ignored and all processing is being done concurrently on the User Interface and that all others are idling in the bg making your utilities bill larger for no reason.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Tim Tyler
    January 2, 2012 at 6:55 pm
    The BMD Windows docs suggest separate cards for the display GPU and Resolve GPU even for their “1 GPU Installation” so I believe that Resolve must be smart enough to make some kind of decision as to which GPU it uses.
    Tim Tyler
  • Joseph Owens
    January 2, 2012 at 7:07 pm
    So then it is not using the UI GPU for color remapping and remains a “single GPU” processor.
    jPo
  • Tim Tyler
    January 3, 2012 at 2:37 am
    Solved – I think.
    In the “About Resolve” app display Resolve shows the number of GPU’s it’s using, and at app start, Resolve will popup a warning if it’s using the same GPU as the displays.
    My About display says I have one GPU, and startup shows no error, so I guess we can assume that Resolve is using the GTX570.
    Now I just need to figure out why I’m only getting ~23fps with h.264 clips with minimal grading…
    Tim Tyler
  • Margus Voll
    January 3, 2012 at 8:03 am
    h264 is bad anyway 🙂 use uncompressed for testing on same rez.
    Margus
