Activity › Forums › Adobe Premiere Pro › Which NVidia Driver to use?
  • Which NVidia Driver to use?
    Posted by Jan Janowski on March 30, 2014 at 5:20 pm
    Hello…. From this link:
    https://www.nvidia.com/object/quadro-certified-drivers.html
    I see that for a Quadro FX 4800 the proper driver I should use for Adobe CS6 Premiere Pro is V311.35
    However, I find that I presently have V320.86 installed… and an even newer version is available….
    Seeing that on this system I will Not be Upgrading from PPRO CS6.0.5 to CC.. I would immediately install V311.35 if I had something Older…
    BUT… I’m running something newer…… And Even newer drivers exist… ?????
    This link I posted is the first and only link that would seem to specify a specific Version Driver…. But I can’t determine if this is just an old link I stumbled onto… that hasn’t been updated or not??
    So I ask for some direction… FOR PPRO CS6 (and other programs in CS6 Master Suite) IS there a “Preferred” NVidia Driver for the Quadro FX 4800 Card?
    Thanks in Advance!
    Looking for 1939 Indian Motocycle
    Jan Janowski replied 12 years, 5 months ago 2 Members · 3 Replies
  • Jan Janowski
    April 2, 2014 at 3:44 pm
    This isn’t an issue, then?
  • Peter Garaway
    April 2, 2014 at 4:51 pm
    Hi Jan,
    I can’t speak specifically to how the latest drivers are performing with CS6 but I can tell you there are currently no open issues with the latest NVIDIA driver (332.76) with the 4800.
    Hope that helps.
    Best,
    Peter Garaway
    Adobe
    Premiere Pro
  • Jan Janowski
    April 2, 2014 at 4:58 pm
    Thank You, Peter!
    Great information to have!!
    Jan
