Activity › Forums › DaVinci Resolve › Which Nvidia cards are supported by Resolve?
Posted by Andreas Wideroe on April 27, 2011 at 6:30 amI think the setting up manual is outdated since I see people using 470, 480 and other boards for GUI and GPU.
Does anyone have an updated list of which Nvidia chips are supported/will work as GUI and GPU?
Cheers,
Andreas—
Norsk Smalfilm AS
https://www.smalfilm.noFilmshooting | Com
https://www.filmshooting.comKevin Wolff replied 15 years, 3 months ago 6 Members · 9 Replies -
Gabriele Turchi
April 27, 2011 at 8:14 amhey Mikhail, did you get a change to test the 470 on the mac ? (your report on the 480 on the hackintosh are very promising …)
thanks
g
Esteban Aguilera
April 27, 2011 at 6:17 pmwell, my 5 cents, i am using hackintosh with a 460 for gui and gpu, and my renders in 1080p prores are more fast than real time, if you need some test tell me.
Luke Maslen
April 28, 2011 at 12:28 amHi Andreas,
The 22 December 2010 edition of the DaVinci Resolve for Mac Configuration Guide is very much up to date with all the hardware we officially support and that we know works reliably. If you are performing mission-critical work, we would recommend you stick with the officially supported hardware so we can help if anything goes wrong.
There will be another update to the guide when Resolve 8.0 is released as it supports new hardware including GPUs from ATI.
Regards,
Luke Maslen
Blackmagic Design -
Mikhail Puzyrev
April 28, 2011 at 7:17 pmThere are plenty of people who has fermi cards in hackintoshes, the question was about reflashed 470 inside original Mac pro.
Gabriele Turchi
May 3, 2011 at 3:35 pmanyone got the chance to test the 470 on resolve having good results ?
ps:Mikhail maybe ?
thanks
g
Gabriele Turchi
May 4, 2011 at 3:28 pmi am wondering …what is the criteria of having this cards flashed for mac ?
i mean all of them can be flashed and used (like is happening for the 470/480?)i am asking because the new GTX590 have 1024 cuda cores !!!! and cost 750usd … (basically 4 times the power of the quadro 4000 for the same price ….
https://www.geforce.com/#/Hardware/GPUs/geforce-gtx-590/specifications
so , how this is possible ???
thanks
g
Kevin Wolff
May 19, 2011 at 4:14 pmIs there any possibility that Black Magic will release the Resolve 8 configuration guide as soon as it is available (i.e., before the release of the software). I plan to get an OpenCL card for use with Final Cut Pro X (which I believe will be released a bit before Resolve 8) and I would like to be sure to select a card that is also compatible with Resolve 8.
Kevin
