Activity Forums Canon DSLR Cameras Which lenses to keep/get
  • Which lenses to keep/get
    Posted by Steve Topper on April 10, 2011 at 12:20 am
    I have a shoot coming up, and I am going to be using a canon 5d for the shoot. However, I also have a t2i that I want to use as a second camera to catch pickups/other angles. So my first question right of the bat is: Will the image will be compatible enough, after some post production fiddling? Or will the t2i footage be glaringly different.
    Okay, second, I will have canon 85 1.8 and 50 1.4 lenses, but I’m looking for a good wide angle lense. (From the previous lenses you can see I am on a bit of a budget, so please don’t waste my time telling me I should get some $2000 Zeiss lens.)
    Most of the shoot is indoors, and thing will be shot relatively close, so there isn’t much need for a super wide lens to capture landscapes or anything. But beyond what I am doing here I want to get something that I can proudly keep for future productions (so no, I don’t want to rent)
    Would buying the 35 f/2 and the 28 f/1.8 be a little redundant?
    Would it be better skip them and get the 35 1.4 instead?
    I have the sigma 30 f/1.4 for my t2i but it won’t work for a full frame. Ought I sell that and just use the wide angle I get for my “standard lens” on my t2i?
    Will I reasonably need anything wider than 28-35 for an indoor shoot as well?
    Steve Topper replied 15 years, 4 months ago 2 Members · 2 Replies
  • Zane Barker
    April 10, 2011 at 10:35 pm
    You seem to think that the only way to get a lens to use I to buy. Why not rent lenses? I only recommend buying a lens if you are going to be using that lens quite a bit over an extended period of time.
    Check out borrowlenses.com
    **Hindsight is always 1080p**
  • Steve Topper
    April 15, 2011 at 10:27 pm
    hmm, excellent idea.
