Activity › Forums › Blackmagic Cameras › Which lenses do you think are most suitable for the Pocket Camera?
  • Which lenses do you think are most suitable for the Pocket Camera?
    Posted by Chris Summers on April 12, 2013 at 8:02 pm
    I’m in love with the pocket Cinema Camera already.
    I was thinking of getting some Rokinon Cine lenses (8mm, 14mm, 24mm, 35mm) and getting a MFT-EF adapter. Which lenses would you guys think are best suited for the most beautiful video?
    Chris Summers replied 13 years, 5 months ago 2 Members · 4 Replies
  • Deleted User
    April 14, 2013 at 8:45 am
    Hi Chris: There are literally hundreds (thousands?) of lenses that can be directly mounted or adapted for use with a camera with a MFT lens mount such as the BMPCC.
    Like many things, concerning lens quality you generally get what you pay for.
    A good place to read about MFT lenses for video use is:
    https://www.dvxuser.com/V6/forumdisplay.php?181-GH-Hardware-Lenses-etc
    The information at the link above is for Panasonic “GH” MFT cameras (such as the GH2 & GH3). Note that the sensor crop factor for GH cameras is 2x, whereas with the BMPCC it’s 3x, relative to full-frame 135 still photography.
    https://www.peterdv.com
    Blog: https://herefortheweather.wordpress.com
  • Chris Summers
    April 14, 2013 at 11:04 pm
    Thanks Peter!
    The crop factor is tough, but I realize the crop factor is relative only to stills cameras and S16 is fairly standard for cinema.
    The issue is that a 35mm lens becomes a tele.. I’m kinda trying to stay on the (comparatively) wider/standard side (24-50mm). I was going to get the Rokinon 8mm/14mm (EF) and SLR HyperMagic 12mm (MFT) lenses, since they are cine lenses, fairly well-reviewed, and stay in the standard range.
    Is this a process you would recommend?
  • Deleted User
    April 15, 2013 at 5:15 pm
    [Chris Summers] “… I was going to get the Rokinon 8mm/14mm (EF) and SLR HyperMagic 12mm (MFT) lenses, since they are cine lenses, fairly well-reviewed, and stay in the standard range. Is this a process you would recommend?”
    Most important, I recommend not buying a lens for a camera which you don’t yet have in hand. 🙂
    And, if at all possible, only buy a lens from a dealer who’ll give you a full refund if you decide to immediately return the lens after testing it on said camera.
    Beyond that, yes: If you need a FOV range that’s relatively wide-ish to “normal” on a 3x crop camera, lenses in the approx. 8mm-20mm range would be ones to consider. Either lenses with native MFT mounts or non-MFT lenses adapted to MFT. It’s interesting to note that most film & TV productions rarely shoot wider than 18mm on S35. Refer to Abel’s FOV calculator for comparisons:
    https://www.abelcine.com/fov/
    DP John Brawley, who advises BMD on camera design and writes extensively about their cameras, has promised another detailed hands-on preliminary test with pre-release BM Pocket Camera. He personally owns several MFT lenses & cameras, and in his work uses a wide range of pro cine cameras and lenses, including some extremely expensive cine glass. He’s very knowledgable. Stay tuned to his blog:
    https://johnbrawley.wordpress.com/2013/04/09/the-pocket-rocket-blackmagic-downsizes-the-bmcc-and-does-a-4k-upsize-of-the-orginal/
  • Chris Summers
    April 15, 2013 at 10:26 pm
    You’re correct, I won’t be buying anything far in advance before purchasing the camera! Plus i was going to get the lenses from Adorama, not eBay.
    I’m going to get an 8, 12, and 17.5 lens for 24/35/50 equivalents.
    Thanks for Abel’s tool, it seems extremely helpful for all crop factor situations.
    I’m waiting until test footage comes out before go ahead and make the pre-order, but it’s going to take some pretty mediocre shots for me to cancel the process. Waiting for Brawley’s review!
