Activity Forums AJA Video Systems Which Kona for me?
  • Which Kona for me?
    Posted by Michael Nichols on October 18, 2008 at 7:14 pm
    I have an 8 Core Mac Pro and 2K scans (which are actually 1868 x 780 DPX – 2perf 35mm) I am using Glue Tools to edit the DPX files in FCP.
    All I need is the ability to monitor out to an HD monitor. Do I NEED a Kona 3? All I am going to be doing is grading in Color and I need the ability to monitor out in HD at 1080.
    Ramona Howard replied 17 years, 10 months ago 7 Members · 26 Replies
  • 26 Replies
  • Gary Adcock
    October 18, 2008 at 9:13 pm
    [Michael Nichols] “I have an 8 Core Mac Pro and 2K scans (which are actually 1868 x 780 DPX – 2perf 35mm) I am using Glue Tools to edit the DPX files in FCP. “
    FYI that is technically not a 2K scan, the 2K moniker has been defined by SMPTE to be a scan that is 2048 or larger and your scans are not even 1920×1080.
    However the only GT implementation is only on the Kona 3 Card, so yes you would need the K3 card.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Michael Nichols
    October 18, 2008 at 9:43 pm
    Thanks. I figured the K3 was my only choice.
    I know it isn’t 2K, but that is the resolution from the 3k to 2k arriscan for my 2 perf 35mm. 2-perf only uses Academy Aperture width since Full Aperture gives you a 2.66 : 1 aspect ratio. Full Aperture 35mm scans at 2K are 2046 pixels across, whereas using only Academy width are 1828 pixels across
  • Bob Zelin
    October 18, 2008 at 11:09 pm
    would you have been happier if you could have chosen the AJA Kona LHe, or Blackmagic Decklink HD Extreme ? You ARE working in 2K with DPX files, right ? You are shooting with an Arri in Film, right ?
    Isn’t quality the only thing you are really concerned with ?
    Bob Zelin
  • Michael Nichols
    October 19, 2008 at 1:08 am
    Yes, but what does one have to do with the other?? By that token, since I shot on 35mm film, did a 2K scan et al, shouldn’t I expect nothing less than Champagne and Caviar? All kidding aside, what does the Kona 3 do for me if i/o isn’t in the cards? All I need is 1080p monitoring capabilities. Unless, and I could very well be mistaken, there is the possibility of monitoring via dual link SDI.
  • Jeremy Garchow
    October 19, 2008 at 1:13 am
    Like Gary said, GlueTools functionality is only operable on the Kona3. it does not exist on the other Kona cards.
    Jeremy
  • Bob Zelin
    October 19, 2008 at 2:11 am
    you just said the last and final word – you need the Kona 3. And YES, you SHOULD expect champagne and caviar – as ALL PROFESSIONALS on this list should demand. ONLY champagne and caviar for ALL OF US – no McDonalds EVER ! Very well put. Anyone that even suggests McDonalds – kill them. (Unless McDonalds is the client – and we use their money to get the champagne and caviar).
    Bob Zelin
  • Paul Provost
    October 19, 2008 at 2:40 am
    what’s going on with the HP dreamcolor monitor and that new nvidia (or is it ati) card that outputs 10 bit over dvi? would that be a monitor only solution. haven’t really put the pieces together in my head yet.
    “HE’S SUCH A GIRL” HD feature film
    grade and finish @ post + beam
    http://www.postandbeam.tv
  • Gary Adcock
    October 19, 2008 at 12:13 pm
    [Michael Nichols] “Full Aperture 35mm scans at 2K are 2046 pixels across, whereas using only Academy width are 1828 pixels across
    2-perf is just now gaining ground on the shooting side and there are other options for the delivery.
    I work on scans larger than 1828 because the client insisted for the FULL 3K scans to get a lager final output then scaled them down in post to 1920 x 1080
    The current software for the Arriscan allows for multiple res files from 2perf scans, since I was told that your files at the res you are working at were the “offline” version, not the finals.
    gary adcock
    Studio37
  • Ramona Howard
    October 19, 2008 at 1:30 pm
    I would suggest that all get their hands on the DVI spec and read it carefully before jumping into any monitoring.
    Cheers,
    Ramona
  • Ramona Howard
    October 19, 2008 at 1:50 pm
    Should have added 10bit monitoring.
    Cheers,
    Ramona
Page 1 of 3
