Activity Forums VEGAS Pro Which is the best render setting for my HD footage?
  • Which is the best render setting for my HD footage?
    Posted by Glenn Delaune on July 21, 2008 at 12:01 am
    Hey guys, which is the best render settings in V8Pro for my HD footage?? I just did a render using the “DVD Architect NTSC DV Widescreen Video stream”, burned to DVD (using standard DVD format) and it looked beautiful on my 1080i LCD TV. So is that setting the best I can get or is there a better setting I should be using?
    Thanks in advance for your help.
    Glenn
    Glenn Delaune replied 18 years, 1 month ago 2 Members · 2 Replies
  • Steve Rhoden
    July 21, 2008 at 1:33 am
    Well Glen, Your finished result speaks for itself…..
    You are following the correct procedure using the standard DVD format
    for pristine playback on a 1080i TV.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
  • Glenn Delaune
    July 21, 2008 at 2:28 am
    Thanks Steve, just wanted to check with an expert before I continue.
    Cheers,
    Glenn
