Activity Forums Avid Media Composer Which is better capture resolution,420 or 411?
  • Which is better capture resolution,420 or 411?
    Posted by Mohamed Bilal on June 18, 2007 at 7:43 pm
    My doubt is at the time of capture, Which resolution is Better for capture from DV? DV420 or DV411?Please tell me all the capture resolution settings for different formats…Thanks…
    Seanski44 replied 19 years, 2 months ago 4 Members · 3 Replies
  • Joe Womble
    June 18, 2007 at 7:57 pm
    This may help you with the information you are looking for.
    https://www.avid.com/onlineSupport/supportcontent.asp?browse=&productID=0&contentID=8513
    Regards,
    Joe Womble
  • Erik Pontius
    June 18, 2007 at 10:54 pm
    you might not have much of a choice. You’re capturing DV? 420 is PAL and 411 is NTSC.
    Erik
  • Seanski44
    July 2, 2007 at 7:32 pm
    not true, you can have 411PAL and 420 PAL, so I assume that both are available in NTSC too.
    We used to use DVCPRO (411) and now use DVCAM (420) I am not too technical about this but believe they’re just different compression formats.
    Hope that helps somehow!
