Activity Forums Apple Final Cut Pro Legacy Which is best? Photoshop, Live Type or Generators for text supers
  • Which is best? Photoshop, Live Type or Generators for text supers
    Posted by Donal O kane on January 30, 2008 at 4:37 pm
    Hi all,
    I was watching Walters latest tutorial Maximum FCP Efficiency with Tabs the other day and I noticed something cool that I though i’d ask about.
    He had imported a photoshop file containing layers of text elements for the text supers that he used in the tutorial.
    That got me wondering, is there a preferred or best way to handle text supers for FCP?
    I’ve been using the FCP text generators and Boris Title 3D generator for one off, ‘quick’ and ‘easy’ supers, but have had the same trouble that others have reported, i.e. not being able to copy text font attributes when I need to change 100+ subtitles fonts size by 1 point. So this method is neither quick or easy unless I’m very lucky and get it right first time.
    The layered phototshop file method walter was using looks like it could be a lot more flexible.
    Would there be any advantage of using illustrator to create the supers .. can FCP read .ai files and get all the layer info and make use of the vector goodness?
    Do these text clips taken from an imported layered photoshop file drop into timelines as still images? and thus do they need rendering etc?
    How about Live Type, i’ve played with it a bit. Is it what I am looking for flexibility-wise for these sorts of jobs?
    It definitely seems like I should be able to have more flexibility than the FCP text generators are giving me.
    Winston A. cely replied 18 years, 7 months ago 5 Members · 5 Replies
  • Walter Biscardi
    January 30, 2008 at 4:45 pm
    [Donal O Kane] “That got me wondering, is there a preferred or best way to handle text supers for FCP?”
    Not really. My methods change depending on the project I’m working on.
    For episodic series like the example in my tutorial, I find it easier to build all the graphics at once in Photoshop.
    For many of our corporate projects, we build using the Boris3D titler.
    We really only use the base Text tool for placeholders as we find the Boris 3D titler cleaner and certainly more flexible.
    LiveType I’ve never been a huge fan of as the movements always seem a little stuttery when it comes back to FCP. If I want animated text, I actually use Motion for that.
    So the short of it is, there is no “best” method for text in my opinion. Just like everything else in FCP, there are different methods depending on the project you’re working on.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Paul Escandon
    January 30, 2008 at 4:48 pm
    LiveType works well as it is part of the FCS package – however I’ve never found much use for it. It can do some cool things – so that’s definitely an option.
    I do most of my non-animated graphics in Photoshop – but I’ve never really liked the way Final Cut handles the PSD files directly. I think this may have changed a bit in FCP 6 – although I’m still using 5.1.4 at my day job and it has problems – especially when you start making heavy use of layer styles. What I’ve always done in Photoshop was reduced the graphic to one layer when I was finished and saved the file as a 32-bit PICT with an alpha channel – Final Cut has always worked really well with this file type in my experience.
    Paul Escandon – Lead Editor @ Outdoor Channel
    Producer | Director – Oremus Productions
    oremusproductions.com | blog
    Apple Certified Trainer – Final Cut Pro
    Adjunct Professor of Media – JPCU
    MacPro Quad-core XEON
    8Gb ram, ATI Radeon X1900 XT, 2TB internal RAID
    2 20″ Dell UltraSharps + Matrox MXO & 23″ ACD
  • Walter Biscardi
    January 30, 2008 at 5:03 pm
    [Paul Escandon] “although I’m still using 5.1.4 at my day job and it has problems – especially when you start making heavy use of layer styles. What I’ve always done in Photoshop was reduced the graphic to one layer when I was finished and saved the file as a 32-bit PICT with an alpha channel – Final Cut has always worked really well with this file type in my experience.”
    FCP has always handled PSD files here just fine, but of course the Layer Styles don’t come through. You just make each layer a Smart Object and then everything transfers fine. No need to merge the layers down or even add an alpha channel. That’s what I do.
    Read my Blog!
  • Arnie Schlissel
    January 30, 2008 at 6:07 pm
    [Donal O Kane] “when I need to change 100+ subtitles fonts size by 1 point.”
    For that kind of thing, you should look at Traffic from xmedit.com. It’s purpose built for just this kind of thing.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Winston A. cely
    January 30, 2008 at 6:30 pm
    I tend to use Title 3D for just about everything, unless I need something elaborate that I can only get in Motion (or in rare cases LiveType). Title 3D is quite powerful and very easy if you know some quick workarounds.
    The basic thing to do is to open up Title 3d (Boris) and create your text just the way you like it. Don’t worry about the size or position. Those can be controlled much easier in the Controls Tab than they can be inside the actual Boris editor. You can adjust anything you need to – Scale, Position, Tumble, Spin, Rotate, Opacity, Tracking, etc. The only times I ever go back into the editor are to actually adjust the overall design or if I’ve misspelled something (which is more often than I care to admit… though, I think I just admitted to it….) If I want the titles to move some specific way that a simple transition isn’t going to work, I’ll do it with the controls in the Controls tab. It takes some getting used to but it’s super quick and avoids going into Motion, Photoshop or other program.
    Even if you have a ton of titles, all you have to do is past the values from your first clip into the other clips. True, that does take some time, but it’s easier than actually going into the Boris editor.
    Having said that, there are some great workarounds in Photoshop (like creating an action to do multiple files) or Motion (like AutoMotion from Digital Heaven). As Walter said, it’s typically project and task specific. It’s super easy for me to use Title 3D, but other find Photoshop easier, so it depends on what you’re comfortable with too.
    I guess this didn’t really help answer your question, but hopefully it gave you something to ruminate on! 🙂
    Winston A. Cely
    Editor/Owner | Della St. Media, LLC
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Mac Pro 3GHz Dual-Core Intel Xeon
    4 GB RAM | Final Cut Studio 5.1.4 | Aja Kona LHe
