Activity Forums Adobe After Effects which framerate for a HD project for PAL broadcast & film copy?
  • which framerate for a HD project for PAL broadcast & film copy?
    Posted by Rikard Lassenius on September 8, 2005 at 8:54 am
    hi, here’s a real newbie question:
    for the first time in my cariier, i’m working on a animation project that is sold to a TV station (PAL) but we also want to make a film copy for festivals and such. the resolution is 1920×1080 but i’m wondering which framerate to work in? so far, i haven’t been able to decide between 24 and 25 fps.
    and how does the whole process go? if i render the final animation as 25 fps
    Michael Becke replied 21 years ago 3 Members · 6 Replies
  • Michael Becke
    September 8, 2005 at 12:56 pm
    I recommend 2 renders
    25fps, 720×576, interlaced – upper field first for your TV version.
    24fps, progressive (ie, no fields) for you Film version
    Hope that helps,
    Michael
  • Rikard Lassenius
    September 8, 2005 at 5:06 pm
    ok, but…
    is there any difference in how i work (24/25)?
  • Michael Becke
    September 8, 2005 at 5:22 pm
    Give me some more detail and I’ll be able to help you a bit more:
    What software are you using? (ie. make a maya animation and composite in AE)
    Are you using any footage or just animating from stills?
    The more detail, the more help I’ll hopefully be able to give.
    Good luck,
    Michael
  • Rikard Lassenius
    September 8, 2005 at 7:42 pm
    well, it’s a sort of (technically) southpark type of thing. my brother paints with watercolor
  • Barend Onneweer
    September 8, 2005 at 9:13 pm
    Well, personally I wouldn’t bother creating 2 versions. Just do the 24p version and then speed it up 4% for PAL distribution.
    That’s what they do for every movie in PAL territory. I figure, if it’s good enough for Star Wars or LOTR, it’ll be good enough for most of us…
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Michael Becke
    September 15, 2005 at 1:02 pm
    Sorry, been busy.
    If it’s all graphics like you say, then you can make the animation… and then afterwards just change the frame rate of the Comp and render at a different frame rate.
    Hope that helps,
    Michael
