Activity Forums Adobe Premiere Pro Which formats Premiere accepts? Video not visible in source and output windows.
  • Which formats Premiere accepts? Video not visible in source and output windows.
    Posted by Sumeet Khurana on March 16, 2012 at 8:52 pm
    Hi.
    I am using Premiere Pro CS3.I have been working on a small documentry.I shooted my footages with a camcorder which delivered output in MPEG2 format.Everything was going fine, Premiere was accepting my MPEG2 format files( with audio). But after some time Premiere still imported my MPEG2 video footages but with no audio.So I decided to convert my MPEG2 video files to audio wav. format and imported them to Premiere Pro to sync them with the video files(without audio) I have imported earlier in Premiere.This is how I have been managing….
    But my real problem started when I opened my this particular documentry film project on other computer. Premiere CS3 refussed to show any footages neither in the source window nor in the output window. It showed instead a brown color screen in the source and output windows much like the red color screen which appears after the files have been unlinked.
    I wish to know does Premiere accept MPEG2 format….? If yes then whats wrong with my project?
    Which are the formats that Premiere Pro accepts happily?
    Tom Daigon replied 14 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Abhishek Kumar
    March 16, 2012 at 10:25 pm
    Is your audio mono or stereo? I know later versions of Premiere allows native editing on a large number of formats and their consumer codecs, including MPEG-2. Not sure about CS3. I’d imagine it does.
  • Sumeet Khurana
    March 20, 2012 at 9:55 pm
    Thanks Abhishek Kumar for replying..My audio is in stereo….I managed to run my film project in Premiere in one of my friend’s machine. Its running perfectly on my machine and my friends’ machine but still I can’t figure out why I cant run my Premiere film project on the second machine I tried earlier…
  • Tom Daigon
    March 21, 2012 at 1:23 am
    From Adobe about PrP 5.5…
    Take advantage of broad format support
    Import and export major video, audio, and graphic file formats, and combine them all in the Adobe Premiere Pro timeline. Adobe Premiere Pro also supports a wide range of hardware, so you can build the editing system that meets your needs and budget.
    Expanded RED support
    Work natively with RED footage, with support for RED Rocket, Mysterium X™, and the latest Color Science and Firmware for RED ONE™ cameras. The Source Settings dialog box gives you full control over RED parameters and allows RMD files to be imported and exported.
    Mixed-format timeline support
    Combine content from all supported formats in the Adobe Premiere Pro timeline without restrictions. High-quality scaling and flexible footage interpretation rules make it easy to produce exceptional output from mixed-format footage.
    Support for all major media types
    Import and export major video, audio, and graphic file formats, including FLV, F4V, MPEG-2, QuickTime, Windows Media, AVI, BWF, AIFF, JPEG, PNG, PSD, TIFF, and more.
    DPX file support
    Use native DPX file import and export to create a 10-bit uncompressed DI workflow. Timecode is preserved throughout import, editing, and export.
    Still-image file support
    Import still-image files in major formats, including PSD, BMP, GIF, EPS, JPEG, PCX, PICT, PNG, and TIFF. Export in BMP, GIF, TARGA, and TIFF formats.
    ASIO compatibility
    Record and play back audio through any multichannel audio card or hardware that supports the industry-standard ASIO protocol (Windows only).
    Video hardware support
    Choose from a wide range of capture cards and other hardware to build the HD, SD, or DV editing system that meets your needs and budget.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Sumeet Khurana
    March 23, 2012 at 7:57 pm
    Thanks Tom Daigon for sharing useful information.
  • Tom Daigon
    March 23, 2012 at 8:00 pm
    You are very welcome Sumeet. Glad to help!
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Rick Schoenbeck
    July 20, 2012 at 3:22 pm
    Tom, I noticed you work with Adobe After Effects. A colleague of mine was trying to help me solve a problem I’m having with importing an HD Quicktime video into my Premiere Pro. All I get is a green screen. He then tried importing the same Quicktime video into After Effects and got the same results. The video was downloaded from a photo/video collections service. Ever heard of this problem?
    Rick Schoenbeck
  • Tom Daigon
    July 20, 2012 at 3:36 pm
    Please give me more details what is the format (size) and codec (compression) of the media. Can you give me a link to where you got i?
    It sounds like the Adobe software doesnt know what kind of media it is.
    So Im guessing its codec related. But getting the info might help clarify things.
    Tom Daigon
    HP Z820 Dual 2687
    64gigs ram
    Caligit HD Pro 2 16TB.
