Activity Forums Compression Techniques Which format to use for video? USB 2.0 Distribution
  • Which format to use for video? USB 2.0 Distribution
    Posted by Xavier De champs on May 21, 2010 at 3:14 pm
    Hi. I´m doing some showreel distribution on USB keys. I´m looking for a codec, that will stream of the USB being compatible with..say…USB 2.0 HiSpeed.
    The original footage is DV-PAL coded into Prores footage.
    I need it to run on both PC and MAC, and be playable with standard players.
    Question:
    1. Is there a format, which will play with default installations on both OSX and Windows?
    2. If not. I will make two different files, and label them OSX and Windows. But which format for each, taking into account the transfer speeds of a USB port. I would prefer to be able to play directly of the key, without the customer needing to copy the materal onto HDD.
    3. Any other things I should worry about?
    PS.
    I´m using Compressor or Mpeg Streamclip to compress the file.
    Daniel Low replied 16 years, 4 months ago 2 Members · 3 Replies
  • Daniel Low
    May 21, 2010 at 5:41 pm
    [Xavier de Champs] “1. Is there a format, which will play with default installations on both OSX and Windows? “
    If you want to cover ALL bases use MPEG-1.
    [Xavier de Champs] “2. If not. I will make two different files, and label them OSX and Windows. But which format for each, taking into account the transfer speeds of a USB port. I would prefer to be able to play directly of the key, without the customer needing to copy the materal onto HDD. “
    This is more about data rate than format check out the transfer specs of USB 2.0 and decide. I’d maybe do one WMV and the other would be H.264 MP4.
    [Xavier de Champs] “3. Any other things I should worry about? “
    Sent from my iPad Nano.
  • Xavier De champs
    May 23, 2010 at 11:54 pm
    Does Leopard and Snow Leopard come standard with the h.264 codec?
  • Daniel Low
    May 24, 2010 at 7:48 am
    Yes they do.
