Activity › Forums › Creative Community Conversations › Which format for lagless editing?
Posted by Samuel Féron on December 10, 2013 at 9:05 pmHi guys
I think I have a fairly simple question for you but I couldn’t find any obvious solution for it in this forum:I have loads of .AVI files imported raw from a simple HD cam recorder. No matter what format I convert them to with my MacX DVD Video Converter (in able to edit them in FCPX) the files begin lagging when I edit them.
Any idea to which conversion settings are the most optimal for the .AVI files so it won’t lag when I edit them?
/SamSamuel Féron replied 12 years, 8 months ago 6 Members · 12 Replies -
Samuel Féron
December 10, 2013 at 9:25 pm -
Gary Huff
December 10, 2013 at 9:29 pmFirst of all, no simple camcorder records in raw .AVI files…so you should give the make and model of the camcorder and what you originally did to generate these “raw” .AVI files (I assume you mean uncompressed?)
This is necessary because I feel that we’re about to introduce some generation loss in this footage.
Daniel Ludwig
December 10, 2013 at 9:47 pmSamuel,
quicktime MOV is a wrapper or container-format that could contain different codecs in it, for example H264, apple pro res, motion-jpeg and so on….a container is the same like bread: there are different breads, grey ones, black ones, with cereals or not…
I guess your application will transcode your AVI to H264-quicktime mov, because there is AAC-audio within the setting, which is a part of the H264-standart.
cu
danny
Shane Ross
December 10, 2013 at 10:20 pmMacX DVD Video Converter is seriously WRONG. MOV is NOT A CODEC. MOV, AVI, MXF…those are WRAPPERS. Canisters if you will, that contain any number of codecs.
I see TO APPLE as a tab…what options do you have in there? ProRes 422 is your best bet.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Samuel Féron
December 10, 2013 at 10:24 pm -
Shane Ross
December 10, 2013 at 10:25 pmiMovie doesn’t do MPEG4…it does Apple Intermediate…
This app is VERY consumer level.
Shane
Little Frog Post
Glenn Grant
December 10, 2013 at 10:45 pmInstead of the app you have there you might try “mpeg stream clip” https://www.squared5.com This is a free download.
That will allow you to convert to Apple Pro Res with the .mov extension. As long as you have enough memory and a fast enough drive, you won’t have any issue speed.
Bret Williams
December 11, 2013 at 12:38 amYou’re thinking of iMovie from like 5 or 6 years ago I think.
Samuel Féron
December 12, 2013 at 5:13 pmGary Huff —> By “raw” I mean imported (dragged and dropped) directly from the camera… So yeah, uncompressed as well. I know the camera model now by the way: Medion Life x47023 (MD 86423)
Glenn Grant —> Nice app! I converted the files to MPEG using the MacX DVD Video Converter (since MPEG Streamclip doesn’t take AVI) and converted the MPEG files to Apple Pro Res with .mov extension, as you said. The problem is that a small file with the duration of 30 seconds and the size of 44 MB in MPEG now fills up nearly 500 MB in Pro Res! And I have loads of these files to edit in FCPX. Surely there must a way to which I can convert to a smaller Pro Res size?
