Which firewire compression should I use?
Hello,
I have a client coming in with several mini-DV tapes and I do have a Sony VX-2000 camera and firewire cable. I’ve never used it as an output device for FCP, though, so I’m wondering what compression setting to use? Of course, the highest video quality possible would keep this client coming back – however, I have no idea why he shot in mini-DV in the first place and then expect high quality! He knows better! I smell the need for some 3-Way Color Correction filters coming up.
In “Easy” Setup, the setups that appear to apply would be DV-NTSC, DV-NTSC Firewire Basic and DV50-NTSC. Which one of these would be best in this case, or is there an even better setup to use? I have all of the AJA LA setups, but they don’t appear to apply here.
Also, I’m assuming capturing via Firewire for mini-DV is the best video quality bet, but I’m used to capturing Uncompressed 8- or 10-Bit with my UVW-1800 Beta-SP. If I can get a mini-DV / DV deck with analog component outputs, would that actually be a better video quality than capturing digitally via firewire?
Thanks in advance for your help with this!
-PatG5 Quad 2.5 Desktop with 4GB Ram, 500GB HD & Fiber Card ~
30″ Cinema Display & 17″ Sony SVGA ~
Swift Data 200 Internal 1.6TB SATA II RAID 0 ~
AJA Io LA ~
Final Cut Studio ~
Sony UVW-1800 Beta-SP ~~~P D Post Productions, Inc. ~
TV~DVD~VHS~CD~WEB
for Corporate Communications, Commercials, Infomercials, Television Programs, Family Occasions since 1983 ~
E-mail PD@PDPost.com ~
Website http://www.PDPost.com ~
Business/Cell Phone (847) 275-5671
