Activity › Forums › Adobe After Effects › Which effecys
Which effecys
Posted by Denis Sivak on January 28, 2017 at 2:28 amI want to ask what effects are in “Young Thug Power” you can find it on youtube I actually like the effects
Jonachan Chainy replied 9 years, 7 months ago 3 Members · 2 Replies -
Roei Tzoref
January 28, 2017 at 4:29 pmI assume you mean this video?
https://www.youtube.com/watch?v=_-QxSh19nDIyou need to be specific: show exactly what effect or effects you want to replicate by specifying the right point in time.
Roei Tzoref
After Effects Artist & Instructor
♫ Ae Blues TutorialsSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jonachan Chainy
January 29, 2017 at 12:44 amwith the clouds, its harder than just adding effects.
you need to add a mask with the pen tool on a copy of a video you want it on.
then on the timeline click the drop-down and right click the mask. (if nothing shows up make sure you are in the right composition panel and that your mask is closed.)
once you right click the mask click track mask
a panel will show up on the right.
click the forward triangle
when your mask it tracked both ways, slap some clouds between the masked video and the original video.the layers should go like this
piratedsong(2).mp4
cloud timelapse.mp4
piratedsong.mp4or whatever you call them
then just click them all and pre compose them all.
now drag the “curves” effect onto the pre composition and adjust the colors to your hearts content.good luck
-jon
