Activity › Forums › AJA Video Systems › which drives for fcp 5.1.4?
Posted by Lee on April 25, 2007 at 8:25 amHi
Which drivers should I use for FCP 5.1.4 with the I/O
The CD that comes with the AJA I/O only has version 1.3.1 and when I install it does not work.
On the cd it also does not have the Control panelDo I need to download this?
Paul
Tony! Hulette replied 19 years, 5 months ago 2 Members · 3 Replies -
Tony! Hulette
April 25, 2007 at 2:03 pmHi Paul,
No matter what hardware you buy and connect to you Mac you always (ALWAYS) want to go to the developers website and download the latest drivers, etc. As a rule of thumb, never use the ones that come on a disk with your product (including the Io) without checking for newer versions on their website first.
Here’s the link to download the latest versions: https://www.aja.com/html/support_Io_swd.html
Tony!
Lee
April 27, 2007 at 12:16 pmHi Toni
Thanks for your help
I have FCP 5.1.4 installed
Aja I/O Version 3
and Pro control 1.1It seems to read the digi beta and sees a signal present in the control panel but when I go to FCP it just says the video is disabled in the capture window
It can control the deck but not picture out. I just bought two of them and both have the same problem. is it something I am doing wrong?
Paul
Tony! Hulette
April 27, 2007 at 10:16 pmHey Paul,
Assuming you don’t have any other Firewire devices connected to your Mac, and that you don’t have any conflicting codecs/drivers installed (avid, blackmagic, etc), I would say its likely you have just configured the control panel or Io capture setting incorrectly. I would suggest a quick call to AJA’s wonderful tech-support so they can help you identify the problem and hopefully give you a quick/easy solution to it.
Oh, a couple of things that you should check as well:
Make sure these two items are not true:
1. External video is set to
