Activity › Forums › Adobe After Effects › Which compressor between AE and FCP
  • Which compressor between AE and FCP
    Posted by Ken Olson on April 19, 2009 at 12:59 pm
    I’m doing a project that’s an After Effects (6.5) animation and I’m editing it in Final Cut Pro. What I’m doing for now is exporting a Quick Time using the H.264 compressor from After Effects, then importing it into FCP (which I think is set on the DV/DVCPRO NTSC compressor) and rendering it. It looks okay, but it’s pretty “pixelly” and I know there is probably a better compressor to choose, that if I set both programs on it, there won’t be as much image quality lost.
    Does anyone know which compressor is best for this?
    Justin Vaillancourt replied 17 years, 5 months ago 3 Members · 2 Replies
  • Dan Blaim
    April 19, 2009 at 5:32 pm
    I would recommend exporting out of AE with a DV/DVCPRO compressor (codec). That way it will be native in FCP and there won’t be a need to re-render once the clip is placed in the timeline.
    Animation codec works well if you need an alpha channel for transparency or if space isn’t critical, (larger file size OK) I use 8-bit uncompressed with good results.
  • Justin Vaillancourt
    April 20, 2009 at 1:12 pm
    If your end goal is a DV/NTSC sequence in FCP then render DV/NTSC in After Effects. Rendering in AE then FCP again will only re-compress your movie. H264 is an end-user codec that should really only be used for final display. It does not edit well in FCP and does not re-compress well.
    If your not limited to DV/NTSC then try and stay ProRes the whole way. I’ve also had a lot of success with the Photo JPEG codec.
