Activity Forums Compression Techniques Which codec am I missing in this mp4?
  • Which codec am I missing in this mp4?
    Posted by Lucy Moon on February 17, 2016 at 5:23 pm
    Hi all.
    I am trying to re-edit some .mp4’s which my 2014 Mac (10.9.5) refuses to open in Premiere CC and Quicktime 10.3
    They play in VLC (doesn’t everything!) but I can’t recompress with MPEG Streamclip, and Flip4Mac couldn’t read them. I’m pretty sure they came from a Windows’ based editor’s setup.
    (EDIT) I’m pretty sure it’s ms-mpeg4v2-macosx.sit I’m looking for – some older Windows codec, but any links to it on the web are dead (/EDIT)
    (EDIT2)I may have been on the wrong path above with that codec, since the other editor uses Media Encoder with the same settings as me, but on Windows. I think they have corrupted somewhere in transit, or my machine is crazy… Am uploading a sample file, if anyone loves this kind of mystery, msg me (if you can on creativecow?) (/EDIT2)
    I’d rather find the codec if I can so I can import them to Premiere…
    This is iMediaHUD output..
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 170 MiB
    Duration : 35mn 28s
    Overall bit rate mode : Variable
    Overall bit rate : 671 Kbps
    Encoded date : UTC 2015-02-27 12:55:14
    Tagged date : UTC 2015-02-27 12:55:14
    ©TIM : 00:00:00:00
    ©TSC : 25
    ©TSZ : 1
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Baseline@L3.1
    Format settings, CABAC : No
    Format settings, ReFrames : 3 frames
    Format settings, GOP : M=1, N=33
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 35mn 28s
    Bit rate : 543 Kbps
    Width : 1 024 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.037
    Stream size : 138 MiB (81%)
    Language : English
    Encoded date : UTC 2015-02-27 12:55:15
    Tagged date : UTC 2015-02-27 12:55:15
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 35mn 28s
    Source duration : 35mn 28s
    Bit rate mode : Variable
    Bit rate : 126 Kbps
    Maximum bit rate : 213 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 31.9 MiB (19%)
    Source stream size : 31.9 MiB (19%)
    Language : English
    Any ideas?
    Thanks.
    MacBookPro 2.8 GHz intel core i7/ 16 GB RAM / NVIDIA GeForce GT 750M 2048 MB
    Adobe Creative Suite Cloud
    Lucy Moon replied 10 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
