Activity Forums Blackmagic Cameras Which Black Magic Cam?
  • Which Black Magic Cam?
    Posted by Philippe Orlando on September 28, 2014 at 8:02 pm
    Hello,
    I’m in pre production and was counting on a Red from a local Cable TV station, but the availability is unworkable. So now I’m looking at the cheapest solutions to come as close as what the Red, the Scarlet to be precise, would have given me.
    The difference in price between the three models of Black Magic Cam is not that huge. I’m not sure I understand the 2.5 K model?
    I certainly do NOT have a contract to be distributed in a theater, so it’s not like I need to shoot 4K at all cost. I was going to use the Red because it was free.
    So which cam should I get? I have experience shooting, I’ve shot a film before with a Canon XH A1, 6 years ago. Since them just small shorts.
    Thanks for any input
    Philippe
    Bill Bruner replied 11 years, 12 months ago 2 Members · 3 Replies
  • Bill Bruner
    September 29, 2014 at 3:34 am
    Hi Philippe – even if you’re not planning theatrical distribution, if your budget supports it, you should shoot at 4K (UHD) with a Super 35mm sensor.
    UHD will make your life a lot easier in post – allowing for full HD resolution crops and “camera movement” within the frame.
    And Super 35 will get you closer to cinematic depth of field than the smaller sensor on the 2.5K Cinema Camera.
    If your picture includes fast moving action or camera moves, you should also seriously consider a camera with a global shutter to eliminate CMOS “skew” and “jello”.
    The only Blackmagic cameras with these features (Super 35, UHD, and global shutter) are the $2995 Production Camera and the $5995 URSA EF ($6495 for the PL mount version).
    If you can afford it, I recommend the URSA. Pro sound inputs, dual CFast card recording and a large, bright built-in monitor make this camera much easier to shoot with than the ergonomically challenged Production Camera.
    Here is what URSA can do:
    https://vimeo.com/106428907
    https://vimeo.com/104918710
    https://vimeo.com/103050535
    This is a serious production camera that will be competitive with RED – for a lot less money.
    Hope this is helpful and good luck with your picture!
    Bill
    Hybrid Camera Revolution
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Philippe Orlando
    September 29, 2014 at 7:09 pm
    Well, you do work for Black Magic Camera, don’t you?
  • Bill Bruner
    September 29, 2014 at 8:26 pm
    I wish. Maybe they would give me a free URSA 🙂
