Activity › Forums › Avid Media Composer › Which Avid HD Codec is recommended?
Giulio Tami replied 14 years, 11 months ago 5 Members · 11 Replies
Giulio Tami
October 7, 2011 at 11:42 pmHello there.
This is Giulio from italy, sitting in front of Avid MC 3.0.5 (no AMA).
Importing a native h264 CanonMarkII file.
Importing it both in 1:1 and/or 1:1x codec.
Importing it both in RGB and/or RGB “dither colors”.
Immediately re-exporting the file from source into either 1:1 or 1:1x or uncompressed or no-compression(none) mov files.The result should be absolutely NO difference between this export and the original file, right?
lossles in.
lossless out.
Truth is that the exported file has noticeable differences:
1) output file color is poorer… meaning the output file is desaturated. Specially on reds.
2) the output is slightly darker maybe 4/5% than the original, let’s say…
3) I can definitely see compressionShould we consider I did something wrong which is possible even if I’ve been an avid editor for 10 years, now…
Or should we finally state once and forever that avid 1:1
IS NOT LOSSLES AT ALL?Another consideration:
Canon MarkII files run around 45 mb/s.
Importing them into a dnxhd 120 codec should give them range enough (dnxhd120 is 120 mb/s which is almost 3 times what needed to deal the native canon bitrate…)
But once exported into an uncompressed file… the result is soooo damn shitty compaired to the original.Please someone help me !!!
