Activity › Forums › Apple Final Cut Pro Legacy › Which audio format?
Which audio format?
Posted by Matthew Cohn on March 27, 2009 at 8:12 pmHi,
I need to import audio to Final Cut from a CD, and I’m not sure which is the best format to use, wav, mp3 or aiff?
Thanks so much,
Matt
Matthew Cohn replied 17 years, 5 months ago 4 Members · 7 Replies -
David Roth weiss
March 27, 2009 at 8:18 pmMatt,
aiff at 48khz is native in FCP. Always try to stick with that.
Music CDs are typically recorded at 44.1khz however, which should still play just fine in FCP nonetheless.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Matthew Cohn
March 27, 2009 at 10:36 pmDavid, thank you, that is very helpful. The audio I’m importing is actually of an interview that was transferred to CD from tape, not music. Would it still be at 44.1 khz, and do the same parameters apply?
Thanks again,
Matt -
Rob Grauert
March 28, 2009 at 4:53 am“The audio I’m importing is actually of an interview that was transferred to CD from tape, not music. Would it still be at 44.1 khz, and do the same parameters apply”
I believe, generally, camcorders record 16-bit 48Khz. So if the person who burned the CD for you captured the audio from the tape and burned it directly to CD, it should be 16-bit 48KHz, but you can check by bringing the audio file into iTunes, select the track, press Apple + I. That will bring up the information about the audio clip.
Robert J. Grauert, Jr.
Matthew Cohn
March 28, 2009 at 12:44 pmRobert, I apologize for not being more specific in my reply to David’s answer. The interview that was transferred to CD was originally on analogue tape, the interview is from 1981. Do you know how this might change my handling of such media, if at all? On the other hand, your answer (which was informative, thank you) is a perfect lead in to another question I had. Is there a program better suited than Itunes for getting media onto the hard drive from a CD before importing it into Final Cut?
Thanks again,
Matt -
Kai Cheong
March 29, 2009 at 3:55 pmHi Matt, if you have FCP, you should also have Compressor installed – it’s a very useful tool for such situations and relatively easy to use.
If you drag and drop your audio files from your CD, you could batch re-encode them as AIFF 48k/16bit for editing use in FCP.
Kai
FCP Editor / Producer with Intuitive Films
https://kai-fcp-editor.blogspot.com
Now ‘LIVE’! Check Out The Intuitive Films Blog @ https://intuitive-films.blogspot.com
At Intuitive Films, We Create: TV Commercials, Documentaries, Corporate Videos and Feature Films
Visit us @ https://www.intuitivefilms.com
MacBook Pro 2.4GHz | 4GB RAM | FCP 5.1.4 | Mac OS X 10.5.2 -
David Roth weiss
April 5, 2009 at 4:57 amOops, sorry I didn’t get back to you Matt, but I’ve been offline for a few days. Kai gave you a good working solution however.
THNX Kai…
David Roth Weiss
Director/Editor
Matthew Cohn
April 5, 2009 at 1:54 pmThanks for your help, Kai and David, that is the solution I will use!
Matt
