Activity Forums Adobe Premiere Pro Which Audio Filter to Use?
  • Which Audio Filter to Use?
    Posted by Lois Heckland on January 12, 2010 at 7:07 am
    I’m not sure which audio filter to use. Hopefully one of you knows an answer.
    I have a clip where a girl with a high-pitched voice is talking and there is a deep, low-pitched crowd murmur behind her. I know there must be a way to separate out the pitches so I can make her voice a little more prominent and the crowd a little softer. Any ideas?
    Brian Barkley replied 16 years, 8 months ago 3 Members · 2 Replies
  • Clint Milner
    January 12, 2010 at 10:33 am
    Try EQ and/or a High Pass Filter.
    You can amplify the frequencies over 5k and attenuate everything under 3 or so.
    Those are example numbers, of course you’ll have to play around and adjust to your specific frequencies, but that should be a start.
    Clint
    Adobe CS4 Master Suite
    Vista Ultimate 64 SP1
    Intel Core i7 920 @ 3.60GHz
    12 GB DDR3 RAM
    NVidia Quadro FX 3700
    Matrox RT.X2 LE Capture Card
    4 TB RAID 5
  • Brian Barkley
    January 12, 2010 at 3:17 pm
    There is a very inexpensive software that Izotope makes and I used it all of the time for separating unwanted noises from the voice track. This is better than anything you will find in Soundbooth, and it is only $349.
    https://izotope.com/products/audio/rx/
