Which 8-bit codec should I use?
I am a bit confused about which of the 8-bit codecs that are available would be best.
I always assumed that Blackmagic 8-bit would be it. When would I want to use “Blackmagic 8-bit (2vuy)” or “Blackmagic 8-bit(VOO)”. I will be mastering to DigiBeta via SDI. The majority of my sequences are imported graphic files. Any guidance on this would be appreciated.
