Activity › Forums › Compression Techniques › Whether it is interlaced
  • Whether it is interlaced
    Posted by Alejo Serra on February 21, 2010 at 4:48 pm
    Hi!
    If this is not the appropriate forum to explaining my question, But could find no other and is an issue that has me crazy.
    There is some program where I can look at whether a .Avi or a .Mov that I pass is progressive, Interlaced, Deinterlacing? And if it is interlaced know what the correct order?
    And could start working with the knowledge that I'm not doing bad
    Thank you very much and greetings!!!
    Alejo Serra replied 16 years, 7 months ago 2 Members · 2 Replies
  • Daniel Low
    February 21, 2010 at 9:11 pm
    Most good transcoding applications will give you that information.
    Also look at MediaInfo – if you are on a PC – or Quicktime with Perian if you are on a Mac
    Sent from my iPad Nano.
  • Alejo Serra
    February 22, 2010 at 1:52 pm
    I used MediaInfo and is seeking, Sampling, Color depth, Interlaced…
    Thank you very much!
    The only thing he says is the correct field order, If lower or upper, As you can know that?
    Thanks again
