Activity › Forums › Adobe After Effects › Where’s the AEP for the Head-turning Tutorial in the Manual
  • Where’s the AEP for the Head-turning Tutorial in the Manual
    Posted by Roland R. kahlenberg on February 26, 2017 at 9:57 am
    Hi folks, I just purchased ReFlex and all is swimmingly good except for a full-body morph I’m doing right now. Hand and body movements are done and look good. But I can’t get the head turn to look good – I’ve created a monster! ☹
    A related Q – for a head turn (very similar to the tutorial in the manual, should both the From and To frames match, on each frame, in terms of head action/profile/perspective action? Currently, I’ve got a few frames where the From frame is ahead of the To frame when the head turns – and I’m wondering if this is the issue.
    And regardless of the answer to the Q in the above para, a look at the AEP for the head-turn Moving Morph tutorial would be good too.
    Cheers
    – Roland Kahlenberg
    TypeGEMs – the Definitive Type Gizmo for AE
    https://broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
    https://www.broadcastgems.com/mographintensity_shapestext/
    Roland R. kahlenberg replied 9 years, 7 months ago 3 Members · 3 Replies
  • Peter Litwinowicz
    February 27, 2017 at 5:48 pm
    Yeah, you pretty much want things to “more or less” match from frame to frame… and sometimes things need to be separated into different layers if objects cross. Just the nature of morphing.
    That said, the RE:Flex morph projects and footage we have available (including head-turn morph) are located here: https://help.revisionfx.com/tutorial/78/ Make sure to read the README file because it points out things “of interest” in the supplied projects.
    Pete Litwinowicz
    RE:Vision Effects
  • Pierre Jasmin
    February 27, 2017 at 5:52 pm
    FYI, they are also individually listed under the DOWNLOAD section of https://help.revisionfx.com/album/24/
    You have to scroll down to see these
    Pierre
  • Roland R. kahlenberg
    February 28, 2017 at 3:32 am
    Thanks Pete and Pierre. BTW, I had the other links/files but not the one that Pete provided.
    Cheers
