Activity › Forums › Apple Final Cut Pro Legacy › Where’s media located
  • Where’s media located
    Posted by John Sutherland on September 16, 2005 at 4:33 am
    OK. I KNOW I have seen this on the COW, and even used it at least once, but my search does not reveal the answer… Whats the trick to revealing in the browser the actual HD location of the file? I’ve got a few files that ended up in the wrong project file, and I’d like to find ’em.
    John Sutherland
    Quicksilver 867
    1.12 gb ram
    Atto UL3D w/firmware 1.6.4
    Huge 1.2TB Dual Max
    FCP 4.02
    CW 4.01
    OSX 10.2.6/QT 6.3
    Radeon 9000 w/2 17″ crt monitors
    Nick Meyers replied 21 years ago 6 Members · 5 Replies
  • Tony
    September 16, 2005 at 6:07 am
    I am sorry to tell you John but these files are now invisible and will require hiring a HD private investigator to find the files for you.
    Please call the following HD PI’s
    1-800-Files-be- Found
    877-Files-Are-US
    Ok just kidding
    Right click on the file in the browser and select item properties which will have a column telling you where the clips is on the HD. Then you can either import then to the right project or use the finder to move them to the right project folder.
    Tony Salgado
  • Bouncing Account needs new email address
    September 16, 2005 at 11:08 am
    Or. just use the standard Mac “Find” function.
    Click on the desktop, hit “Apple F”, type in the first few letters of the file’s name, and hit “enter”.
    Unlike Avid files, FCP files have the same name in the Capture Scratch folder as in the Browser.
  • Mediacentral
    September 16, 2005 at 2:35 pm
    If you are in the process of logging and capturing, you can also go to to the “capture settings” tab and click on “Scratch Disks.” That will show you where you video, audio and even render files are going.
  • Bill
    September 16, 2005 at 3:13 pm
    i am not sure if this is the answer your looking for but, if the file/files are in an open project in that bin ctrl-click on the item and choose item properties under the format tab you will see a source lien that will direct you to the file.
    “Reach for the sky cause tomorrow may never come”
    -Mike Ness
  • Nick Meyers
    September 17, 2005 at 11:35 am
    easiest way is to open the “source” column in the browser.
    shows you the path.
    getting there is manual in FCP4, but can be done now from within the app in FCP5.
    got mine mapped to Shift R (for “reveal”, like in iTunes)
    cheers,
    nick
