Activity › Forums › Apple Final Cut Pro Legacy › where to put plugins fcp5
  • Jerry Hofmann
    June 17, 2005 at 2:01 pm
    Old should work just fine. HD/Library/Application Support/Final Cut Pro/ plugins
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Deditster
    June 17, 2005 at 2:30 pm
    thanks,
    I will try that.
  • Bret Williams
    June 17, 2005 at 4:25 pm
    In the latest tips and tricks from the LAFCP users group they point out you can add plugins by doing a simple get info command on the app itself. There’s a add plugin area, and you can also turn plugins on and off.
    Would be nice if Apple actually included this function within the program akin to macromedia products. Especially since FCP was a macromedia product first! 🙂
