Activity › Forums › Adobe After Effects › Where to look
Where to look
Posted by Brian Mills on September 4, 2019 at 12:36 pmHey all
I am needing to replicate this look. I am having trouble coming up with the chevrons and the pulsating colors on the outer parts of the video. What techniques or filters should I be working with in your opinions?Cassius Marques replied 6 years, 11 months ago 3 Members · 7 Replies -
Eric Santiago
September 4, 2019 at 1:07 pmI would be interested in looking at the example but a zip file is a bit of a no no in my parts.
Can you upload on a review site e.g. Vimeo, Youtube. frame io, etc…
Zips are a bit scary on both Mac and PCs. -
Cassius Marques
September 4, 2019 at 1:30 pm“Zips are a bit scary on both Mac and PCs.”
This platform zips everything you upload to it by default. What do you mean scary? Do you get infected with a virus by decompressing? I’m honestly lost with that comment.
“What techniques or filters should I be working with in your opinions?”
Those chevrons seem to be a static mask (with varying degrees of luminance/whiteness) There seems to be also a geometric pattern, with shadows between the elements, that’s using the chevrons as a matte. This pattern is showing through an ongoing diffuse turbulent noise.
All that then color corrected and applied with a blending mode (looks like overlay).
That’s a start but not just it. For example the glowing white sweep is another layer added on top using the same chevron matte.
Cassius Marques
http://www.zapfilmes.com -
Eric Santiago
September 4, 2019 at 2:05 pm[Cassius Marques] “This platform zips everything you upload to it by default. What do you mean scary? Do you get infected with a virus by decompressing? I’m honestly lost with that comment.
“On the nose.
Some corporate networks don’t allow the practise of downloading zip files.
Simple as that.
I use frame io for review and there is a free version. -
Brian Mills
September 4, 2019 at 5:03 pmI feel like the mmain video is got the gradient treatment and the chevrons are comping with scale and timing differences. The one thing I am really struggling with is how the “pixeling” is being done on the edges
Eric Santiago
September 4, 2019 at 5:03 pmThanks, Brian.
Cassius is close to what your needs are.
Its a lot of different precomps and honestly you might even make it your own with a little bit of tinkering. -
Cassius Marques
September 4, 2019 at 5:26 pm“Some corporate networks don’t allow the practise of downloading zip files.
Simple as that.”Do they allow the download of .exe files? Or just the scary .zips?
I’m joking! Mainly because your first post implied there is something wrong with the use of the format when there isn’t. In this case, since this site auto renames, it obviously had a .mp4 inside.
But I guess they can be as scary as stupidity goes from a corporate POV.
Cassius Marques
