Activity Forums Adobe Premiere Pro where to install adobe premiere
  • where to install adobe premiere
    Posted by Uroš King on May 1, 2011 at 8:28 am
    Hi,I am writing for the first time,since the first time I draw up the pc through the use of amateur video processing( also hd and fhd ) whit Adobe Premiere Pro v5.0 cs5.
    The Components should be such:
    -CHASE Cooler Master HAF 912 Plus
    -POWER SUPPLY ATX 750W Chieftec BPS-750C
    -MOTHERBOARD Asus M4A89GTD PRO/USB3, AM3
    -GRAPHIC CARD Gigabyte NV 470GTX 1280MB GV-N470SO-13I
    -PROCESSOR AMD Phenom II X6 1100T Black Edition,box
    -RAM Kingston HyperX DDR3 4×4 GB 1600 MHz ( 16GB )
    -HDD 2* WD 3,5 1TB/7200/SATA III 64MB BLACK
    -SSD Crucial 64GB SATA3 2.5″ C300 ( or better 128Gb )
    -OPTICAL UNIT LG Electronics BH10LS30
    If anyone has any better variant, but not costly, as the day it!
    Above all I ask of installations through:
    1.I would be installing windows7 on the SSD.
    2.For Adobe Premiere I do not know exactly what would be better, to install on the SSD ,
    or at one of the two hard drives, which would be in RAID0.
    Please give me some advice.
    Have a nice day
    Jonas Bendsen replied 15 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Ann Bens
    May 1, 2011 at 9:18 am
    All programm incl. OS should be installed on the C;drive.
  • Uroš King
    May 1, 2011 at 11:58 am
    Thanks Ann Bens
  • George Sey
    May 1, 2011 at 2:50 pm
    Just change the AMD to Intel and increase your drive C
  • Ann Bens
    May 1, 2011 at 2:57 pm
    I second this.
  • Jonas Bendsen
    May 1, 2011 at 9:23 pm
    As others have suggested, the program and OS should go on the C:/ drive (especially if you’re utilizing an SSD for your system drive). However, be sure to select the RAID0 for your scratch drive in any Adobe application (Premiere, Photoshop, etc.) when setting up your projects and preferences.
    This is my life, I edit and edit and edit and edit…
  • Uroš King
    May 2, 2011 at 6:52 am
    Jonas Bendsen, thank´s
    Please tell me,how much space give to the one or both HDD,connected in RAID0 or best 4*HDD in RAID10.I have also a question about RAID, how in a BIOS to set for RAID0 and RAID10 ? And what is the best solution for you in my case ?
  • Jonas Bendsen
    May 2, 2011 at 3:42 pm
    Hi, Uros. I’m not sure exactly what the question is regarding space.
    I will say, “real” RAID (dedicated hardware driven RAID) is much better than the software RAID you can achieve via the system BIOS. If you can afford a dedicated RAID card, I would highly suggest going this route instead of using the MOBO’s software RAID.
