Activity › Forums › Apple Final Cut Pro Legacy › Where to download Final Cut Pro 7
Posted by Fay Gartenberg on August 17, 2020 at 7:26 pmHello,
Does anyone know where you can download FCP7 software? I don’t have a disk drive to install anymore. Thanks!Patrick Donegan replied 5 years, 11 months ago 6 Members · 6 Replies -
Michael Gissing
August 18, 2020 at 2:26 amFCP7 was EOLd so long ago. Unless someone has turned the disks into iso images and uploaded them, you might find it easier to buy an external CD/ DVD Rom drive that plugs into a usb port and install from there.
If you want to download an NLE that is vastly better than FCP7 then I recommend Blackmagic’s Da Vinci Resolve.
Mark Suszko
August 18, 2020 at 3:54 amI was as die-hard for seven as anyone but yeah, if your machine can run it, no reason not to get the free version of Resolve because it is enough like Seven you will like like it was a the version eight that never happened.
Getting copies of seven now involves dealing with perhaps (terms blocked by site filters) so don’t do that.
Robert Withers
August 18, 2020 at 3:00 pmHi Fay,
You can buy FCP7 disks on ebay for reasonable prices. What OS and machine will you run them on?I personally have found Resolve quite different from both FCP7 and Premier Pro.
Good luck,
RobertRobert Withers
Independent/personal/avant-garde cinema, New York City
Currently experimenting with iMac 2019, Catalina
3.6 MHz 8-Core Intel Core i9
16 GB Memory
GPU Radeon Pro 575X (4 GB) -
Danielle West
August 24, 2020 at 8:15 amI would try eBay but make sure your computer can run it. Sadly neither of my machines are able to run fcp7 anymore . If you don’t have any luck on Ebay try amazon marketplace.
Danielle West
August 24, 2020 at 12:36 pmOr post something on the classifieds section of creativecow
Patrick Donegan
September 11, 2020 at 11:51 pmLike Michael said – purchase an USB optical drive – they still have them at walmart and target.
otherwise talk with your contact at Apple.
