Activity Forums DaVinci Resolve Where to apply Lut
  • Where to apply Lut
    Posted by Adrian Brindle on April 12, 2012 at 11:41 am
    So this has been covered a bit before but not enough to be sure.
    I’m working with Alexa footage and have previously applied LUTs to the input.
    It gives different results to the output and is easier to grade as ones grades aren’t being then modified by another ‘grade’ downstream.
    However, previous posts have suggested that applying a Lut on input doesn’t give the maximum benefit of Log C footage – is this true?
    What are peoples experiences of this?
    Furthermore a DCP author has also suggested that he prefers to take a LogC delivery to code but obviously the placing of the Lut would be critical,
    Adrian
    Colourist Air Post, London
    Stig Olsen replied 14 years, 4 months ago 5 Members · 5 Replies
  • Pepijn Klijs
    April 12, 2012 at 4:56 pm
    I have very little experience with luts or log-c, but can’t you create a test lut that blows everything out and then see if you can recover that in your primaries? Just a thought…
    Avid/FCP Editor, Amsterdam, The Netherlands
    http://www.pepijnklijs.nl
  • Teo Rižnar
    April 12, 2012 at 8:36 pm
    I usually use color transformations like LogC-Rec709 etc. in between the grading node tree. For Alexa you can generate different, LUTs from their website and play with them What creatively and in point of digital image math suites your workflow. For DCP delivery I grade all in Rec709 and when rendering out I use custom gamma correction LUT (2.2 -> 2.6) on a “track” nodes and render in XYZ option in render. For my Rec709 calibrated CRT and plasma it works perfect for DCP projections. At least in two different near cinemas on some tests.
    But generally LogC LUT I use one or two operations before the and of node tree. Like having 5 nodes, the 4th node is LUT. But it is not exactly the same for all the projects. You can be a bit creative with this color transformations in what order of grading you use them. Generally using it as input LUT it just gets your options of manipulating image a bit more narrow.
    Hope it helps
    Color grade reel: https://vimeo.com/15480583
    Cofounder of https://nuframe.si postproduction
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Adrian Brindle
    April 12, 2012 at 10:23 pm
    That’s great thanks.
    I wonder what sort of extra creative options people feel and output lut gives over an input lut.
  • Juan Salvo
    April 13, 2012 at 4:55 am
    An output lut retains full latitude all the way through your grade. Letting you use different techniques to extend the dynamic range of the image.
    https://JuanSalvo.com
  • Stig Olsen
    April 14, 2012 at 3:40 pm
    Hi Teo,
    You mean for cinema delivery, but what about television / web?
    What do you mean with the need of applying LUTs in two operations?
    Shouldnt you just apply an (alexa) output lut on, lets say the second node, that gives you the opportunity to grade before and after the Lut?
