Activity › Forums › Apple Final Cut Pro › Where should I save my cache and back up files?
Posted by Megan Brown on February 4, 2016 at 3:54 pmHello,
I’m getting ready to load some video into FCPX and am changing the media location to my external hard drive (instead of the default “Movies” location on my computer).
I’m a little confused about where I should be saving the cache and backups for the same library?
Should I be creating a new folder for every event on my external hard drive, and then setting my media, cache and backups to that folder?
I’m just having trouble organizing these three things for each library.
I have attached a screenshot of my very UNORGANIZED hard drive since I don’t know the best way to organize it all… Any help would be much appreciated.
Devrim Akteke replied 1 year, 9 months ago 8 Members · 14 Replies -
Noah Kadner
February 4, 2016 at 7:17 pmGenerally I’d recommend you just let FCPX do this for you. You definitely don’t need to micromanage at the Finder level. Or if you want more granular control over the process this is a great app:
https://www.arcticwhiteness.com/finalcutlibrarymanager/
Noah
FCPWORKS – FCPX Workflow
FCP eXchange – FCPX Workshops -
Jeremy Garchow
February 4, 2016 at 7:23 pmI put the media location on the external hard drive.
I put the cache on my boot drive (but I have SSD boot drives), as all the little cache files run more quickly not he boot drive than they do on the SAN.
It’s very simple to then grab the cache and trash it if need be, rather than let it live in the library, which is the FCPX default.
David Mathis
February 4, 2016 at 8:01 pmYou are saying it’s best to leave the cache files on the system drive?
Jeremy Garchow
February 4, 2016 at 8:04 pm[David Mathis] “You are saying it’s best to leave the cache files on the system drive?”
That’s what I do, yep.
If you have newer Macs with the PCIe SSD, go for it.
Steve Connor
February 4, 2016 at 8:28 pm[Jeremy Garchow] “That’s what I do, yep.
It definitely speeds the timeline up
Bret Williams
February 4, 2016 at 11:16 pmI leave everything in the library on the raid except backups which by default are in the system drive ( fusion drive). My raid should get better performance than the system drive, plus wouldn’t the cache just be eating up space on the system? Another reAson not to have the library or anything of any size on the system. My time machine also backs up my system drive and I don’t need it backing up cache files.
I do leave files in place quite often, but by the time a project is done and all cleaned up for storing away, I consolidate all the files into the library.
It sounds like the op was still keeping the library in the user movies folder. I would move it out of there. Even if you are keeping it on the system drive I’d keep the library in a folder with other elements for the job like motion projects, psd files, AE projects, etc.
Jeremy Garchow
February 4, 2016 at 11:26 pm[Bret Williams] “My raid should get better performance than the system drive, plus wouldn’t the cache just be eating up space on the system?”
Does your RAID get better performance? My MacPro PCIe SSD gets nearly 900MB/sec. Our SAN doesn’t go that fast per user.
Yes, it takes up space, but when the Cache is a simple package file, it’s very easy to delete. I keep all the caches for all Libraries in one folder called “Caches”. and then I tell Time Machine to not backup the Caches folder. Even so, time Machine is pretty maintenance free and will clean up after itself.
In the old days, you didn’t want to put anything on the internal drive, but those days are over. In many cases, the internal drive is your fastest performing drive.
Bret Williams
February 4, 2016 at 11:34 pmMy internal is a 1Tb fusion. Cache files could eat that up pretty quick. Unless something is in the fusion portion it’s just a single Sata drive.
But I’m not sure what would be in my cache. Renders? I don’t optimize or proxy anything.
Megan Brown
February 4, 2016 at 11:42 pmThanks for all of the replies.
I know this sounds silly, but could someone give me a step by step when it comes to managing these settings initially?
For example, should I:
1. Change my media location to my external hard drive for each separate library
2. Create a folder on my same hard drive labeled “caches” which I should plan to set/move all of my caches to
3. ??? Where should I set my backups to?Does that make sense?
Jeremy Garchow
February 5, 2016 at 12:52 amCache is renders and thumbnails.
Proxy/Optimized should go on your media drive/raid.
