Activity › Forums › Blackmagic Design › Where is this Photoshop plugin?
Posted by Mactrix on October 19, 2006 at 1:00 pmFrank Laughlin replied 17 years, 8 months ago 4 Members · 7 Replies -
Nico Sandhof
October 19, 2006 at 1:13 pm“decklink installer 5.7.2” mit pacifist oeffen,
dann mal inhalt von “blackmagicdecklinksupport.pkg checken,
dort findest du:decklink exporter
decklink importeram besten den ganzen uebergeordneten ordner “blackmagic decklink”
per drag’n drop rausziehen.
dann weisste ja wohin damit. -
Mactrix
October 19, 2006 at 1:21 pmHat geklappt! Komisch dass es nicht normal installiert wurde …
Gleich gibt’s wieder einen Anschiss dass wir kein englisch reden 🙂
Nico Sandhof
October 19, 2006 at 1:36 pmhat vielleicht mit deutscher lokalisierung und photoshop zu tun.
die ordner heissen einfach anders. hat bei mir (und anderen)
auch noch nie geklappt mit dem automatischen installieren.Apology because of German writing. The problem was solved. 😉
Luke Maslen
October 20, 2006 at 3:04 amHi,
I’m glad you have solved the problem but can you tell me which version of Photoshop you are using at the plug-in should have been installed automatically?
Regards,
Luke Maslen
Blackmagic Design -
Nico Sandhof
October 20, 2006 at 6:44 amPhotoshop 7, Photoshop CS, Photoshop CS2 – all the same.
I think the problem is the German localization of the software.
Some important files are called differently.
The automatic installation of this plugins did not operate ever.Perhaps one should copy this Plugins in a directory additionally
for installation with a ReadMe. -
Luke Maslen
October 20, 2006 at 7:13 amHi Nico,
Thank you for providing these details and I’ll pass them on to the engineers and see if there is something we can do about it or at least document it in the Readme file.
Regards,
Luke Maslen
Blackmagic Design -
Frank Laughlin
January 12, 2009 at 7:58 amI’m having the same problem with Photoshop CS4. The plugins don’t install and I can’t find them on the install disc.
– Frank Laughlin
Digitonium
