Activity Forums VEGAS Pro Where is the WMV output interlace setting?
  • Where is the WMV output interlace setting?
    Posted by Luc Enders on September 15, 2008 at 2:49 pm
    How do I set whether the output is rendered as progressive or interlaced with WMV? I don’t see an option in the custom dialogs.
    I assume project properties all apply to the source files, and ‘render as’ is the place to specify the output format settings.
    So where do I choose between progressive or interlace in WMV?
    Luc
    Laszlo Kovacs replied 17 years, 11 months ago 2 Members · 3 Replies
  • Laszlo Kovacs
    September 16, 2008 at 6:01 am
    I’m quite sure Vegas supports only progressive WMV output.
    Your project settings determine how to deinterlace, if your source footages are interlaced.
    Regards
    K.L.
    Kovácsolt Videó
  • Luc Enders
    September 16, 2008 at 1:32 pm
    Ah thanks. I was afraid of that when I noticed only progressive templates:-(. I use now Sony YUV for intermediate as a workaround (and render with another program).
    Downside is that I assume Vegas always deinterlaces at the conversion and then interlaces again when outputting (even uncompressed).
  • Laszlo Kovacs
    September 16, 2008 at 2:32 pm
    [Luc Enders] “I assume Vegas always deinterlaces at the conversion and then interlaces again when outputting”
    I doubt this. I think Vegas does deinterlace only when really necessary.
    Regards
    K.L.
    Kovácsolt Videó
