Activity Forums VEGAS Pro Where is the transition media file located?
  • Where is the transition media file located?
    Posted by Paul Gregory on July 8, 2006 at 8:54 am
    I DVDA you are supposed to be able to combine button actions & media end actions so as to create a transition between menus & menus & titles. To start you are supposed to drag the transition media file. Where is this file located?
    Thanks in advance
    Edward Troxel replied 20 years, 1 month ago 2 Members · 3 Replies
  • Edward Troxel
    July 8, 2006 at 12:38 pm
    [The Old Fart] “Where is this file located?”
    YOU have to make it.
    Edward Troxel
    JETDV Scripts
  • Paul Gregory
    July 9, 2006 at 12:41 am
    I would appreciate if you could elaborate a bit about this. What do you do something like saving a copy of 2 different menus then take them into Vegas & drop a standard transition like cross fade, clock wipe etc & then render this out & import it in DVDA?
    Thanks in advance
  • Edward Troxel
    July 9, 2006 at 3:00 am
    You have to create the transition media. Then in DVDA, you would make the menu button point to that transition media and then set the end-action of the transition media to point to the video that is supposed to play after the transition.
    Edward Troxel
    JETDV Scripts
