Activity › Forums › Creative Community Conversations › Where is the “Stretch” feature in FCPX?
Mansur Oscar replied 12 years, 6 months ago 5 Members · 14 Replies
Andreas Kiel
April 2, 2014 at 4:03 pmAnyway, Where is the hidden Stretch feature for FCPX?, Don’t take me to other apps! 😀 I’m Happy and I’m waiting….
There is no “hidden Stretch feature” in FCP X.
Prepare your source material in a way that it will work and match a given project.-Andreas
Spherico
https://www.spherico.com/filmtools“He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil -
Bret Williams
April 2, 2014 at 5:48 pmA stretch feature wouldn’t make much sense, and while it could be included, it would lead to more user error and distorted videos than anything else.
The only time stretching a video to fill the frame doesn’t introduce distortion is when it was shot or rendered anamorphic, or with a codec that doesn’t shoot fill width like DVCProHD. The latter isn’t called anamorphic though, because it’s native to the codec and format and the edit system recognizes that a certain distortion (stretch if you will) should be applied behind the scenes. Anamorphic however, relies in a tag in the file or the user to tell the app it’s anamorphic. So if you prepared some SD footage in some other app, you should have tagged it as anamorphic and X would have applied the distortion automatically. But you can apply it in the inspector as I mentioned before after the fact.
If you want a stretch feature, just scale the X or Y independently in the inspector. Once it fills the frame, copy that setting and paste the attributes to all like clips in the sequence.
I don’t know anything about all the compressor and QT stuff you guys were discussing. Doesn’t seem like any need to go to compressor or QT 7. I have weened myself off QT7. Not even installed anymore.
Bill Davis
April 2, 2014 at 9:35 pmTo simplify further, here’s the recipe.
In any X storyline, click on the clip you want to “stretch”
Open the inspector and go to the SCALE command.
Notice the small triangle to the left of the Scale and click to “twirl” it open.
That will give you independent control of the X and Y axis.
You can then input any size difference you want into either dimension independently. You can do the stretch by “eyeball” or you can input extremely precise numbers by double clicking on any blue “value” field and entering a numeric value including decimal points out the wazoo. (technical phrase)
Hope that helps.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Mansur Oscar
April 4, 2014 at 11:01 amSorry to late reply…
Well I thank to you all,
and seems at last, there is no stretch button in FCPX 10.1
Thanks again.
