Activity › Forums › Maxon Cinema 4D › Where is the Shortcuttable file in the C4D R20 Folders?
  • Where is the Shortcuttable file in the C4D R20 Folders?
    Posted by Simow Labrim on April 24, 2019 at 1:54 pm
    Hi! I am trying to move my Hotkeys from C4D R19 to R20, but I am not finding the Shortcuttable file inside the R20 installation Path.
    Simow Labrim replied 7 years, 5 months ago 2 Members · 2 Replies
  • Jim Scott
    April 24, 2019 at 11:12 pm
    On a Mac it’s in Users > “User name” > Library > Preferences > MAXON > Cinema 4D R20 > prefs. Or it can be found by opening Preferences in C4D (Edit menu, or Cmd + E) and clicking on the “Open Preferences Folder” button in the lower left corner (which also has the path displayed next to it). As always, make a backup of the original just in case.
  • Simow Labrim
    April 25, 2019 at 11:23 am
    Solved, Thank you!
    I just copied and pasted the file in the prefs* path of R20 and it worked fined.
    1 – I copied the Shortcuttable.res from C:\Users\PcName\AppData\Roaming\MAXON\Cinema 4D R19_BFE04C39\prefs
    2 – I pasted the Shortcuttable.res in C:\Users\PcName\AppData\Roaming\MAXON\Cinema 4D R20_4FA5020E\prefs
    *I noticed that there is no Shortcuttable file to overwrite in the R20 Path, I just Past it there anyway and worked fine.
