Activity Forums Adobe Audition Where is the Rumble-filter in Audition Cs6
  • Where is the Rumble-filter in Audition Cs6
    Posted by Janus Vinther on July 3, 2012 at 9:40 pm
    Is there anyone who know where the Rumble-filter (from Soundbooth) is hidden in the new Audition Cs6. It seems that Adobe made a fusion of Soundbooth and Audition Cs2. It was wise to do that 🙂 But I miss the nice clean-up filter “Rumble” I used alot when using Soundbooth. This filter was nice to remove microphone wind-rumble from video-recordings. The cool idea is to show the sound as a graph and then heal part of the sound. Why did Adobe remove the rumble-filter? Is there a similar filter in Audition Cs6? I tried to remove the 60 hz in the EQ. It destroys everything.
    // Janus.
    Janus Vinther
    Bill Gallagher replied 11 years, 5 months ago 4 Members · 3 Replies
  • Joseph W. bourke
    July 7, 2012 at 3:55 pm
    I dont’ think there is a Rumble filter in the sense of a labeled preset. You would most likely do this in the EQ section:
    https://helpx.adobe.com/audition/using/filter-equalizer-effects.html
    Or use a sample of your rumble (noise floor), then remove that from the clip – a very easy process. Here are some useful charts of audio sound frequency, in case you don’t already have one:
    https://audiofederation.com/blog/archives/899
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Phil Williams
    February 5, 2014 at 2:55 am
    The Mic-Rumble filter is located under
    EFFECTS -> FILTER AND EQ -> FFT Filter -> Kill the Mic Rumble
    Hope that helps.
    Bit late responding, but…
    Best,
    Phil
    philsvoiceovers.com
  • Bill Gallagher
    April 8, 2015 at 12:44 pm
    I’m interested in using Audition CS6 to remove turntable rumble, which is a low-frequency artifact of turntable motors. The “rumble” filter used in Soundbooth was for that. I’m not sure what “Mic-Rumble” is supposed to mean.
