Activity Forums Apple Final Cut Pro Legacy Where is The Final Cut Pro License Data??
  • Where is The Final Cut Pro License Data??
    Posted by Mark Linthicum on July 18, 2006 at 7:47 am
    I am trying to install FCP 5.1 and I get an error saying I do not have permission to write license data. Anyone know where this is so i can fix it?
    Thanks, Mark
    Mark Linthicum replied 20 years ago 3 Members · 3 Replies
  • Steven Gonzales
    July 18, 2006 at 2:12 pm
    I think you need to trash this file:
    /Library/Application Support/ProApps/Final Cut Studio System ID
  • John Pale
    July 18, 2006 at 2:16 pm
    The System ID’s are here…
    Make sure the admin account has Read and Write access to this folder using “Get Info” and make sure you are actually logged in as an admin.
    There are also 2 files in Library/Preferences called com.RegFinalCutPro.plist and com.RegFinalCutStudio.plist which may also relate to this. Make sure you have read write access to that folder as well.
    Run a permissions repair using Disk Utility, even if you repair those two folders manually, as you may have other errors.
  • Mark Linthicum
    July 18, 2006 at 9:36 pm
    Thank you Thank You it is up and running!
