Activity › Forums › Adobe After Effects Expressions › where is the error in this expression?
Posted by Jasford Muldoon on July 28, 2018 at 4:30 am
this must be a glitch there is no error in this expression from what i can tell
Jasford Muldoon replied 8 years, 1 month ago 2 Members · 4 Replies -
Dan Ebberts
July 28, 2018 at 6:10 amTry using the match name:
linear(effect(“ADBE Geometry2”)(“ADBE Geometry2-0003”),100,108,0,1)
Dan
Jasford Muldoon
July 28, 2018 at 3:43 pmwell it doesnt ive me an error but doesnt the expression doesnt actually work
not sure why its doing this very weird
jasford
Dan Ebberts
July 28, 2018 at 3:49 pmThat is strange. It works fine in my test setup, but I’m not sure what you’re using it for exactly.
Dan
Jasford Muldoon
July 28, 2018 at 5:45 pmI have some keyframes set on a transform that I added to an adjustment layer, I then used the linear(effect(transform)scale),100,105,0,1) (or whatever it is) expression to link my s_shake settings to the transform so it shakes at the same time as the scale goes up but idk why it gives me an error, it is definitely a bug
